  • Replies 72
G E T R I D O F T H E G K T E C H F A N :yes:
I had heat issues for the first time ever after replacing the fan from stock to GKTECH, changed them back last weekend and test at SMSP and temps are back to perfect!
Drove the car on saturday when it was pissing down rain, maybe 12deg outsde crusing at 60km/h in 4th gear doing 2000 revs. Temps reached 120deg.
> Put standard fan back on (not even a good quality one, i cut about 1/3 of each blade away so it didn't foul on intercooler piping)
> New coolant
> Bleed system
> Has not gone over 80deg so far
Seems like Matt may be correct.
> New coolant
> Bleed system
Awesome! Its the only change on my car and its sorted! :yes:
maybe the gktech fan is turning in the wrong direction or has the blades mixed up. so instead of pulling in air thru the radiator.. its pushing it.
This was my first thought too, but all checked out OK, fan was just rubbish!
bottom line, it's just shit lol
same thing on my mate's S15, OEM fan cools better.. the GK Tech one just makes loads of noise and that's it
Don't know whats going with you guys gktech fans but mine worked great since ive chucked it on noticed 2-3degrees improvement and Ive tested mine in mid 30 degree days on the track.
There is quite a few of us that have had issues... Post a pic of your setup for comparison?
The blades on the OEM fan are way bigger and work so much better... They are closer to the radiator too!
LOL then it has to be really utter crap :rofl2:
how bout other electric fans? the Billion one seems fine... or there's an american brand as well.... cant rem the name
i was using a japanese branded fan on my S13.. temps were exactly how i wanted them every time.
The old engine fan does a hell of a job! No need for thermos etc...
actually once the engine is warmed up, there isnt a need for a thermostat when u are on the track. in case it might impede the flow plus... if the thermostat jammed... u'd have a problem. happened to me before..
Thermo = Electric fan... See above post :P
Negative, the fan was on the correct way 110% sure.
Heres a photo of my bay as you can see no special ducting or anything just std shroud with the koyo rad and lol half of whatevers left of the plastic undertray. Weird why some setups works some doesnt.post-50426-0-52675600-1393827135_thumb.jpg
OP what car do you have I was also at matsuri last weekend in the white 33 with bogged up rear quaters.
Edited by boostn0199
I have had the same troubles with over heating, after a good flogging of the car would get pretty hot, hotter than it usually has, investigated more and found a coolant leak, fixed that, tested again, same thing was happeing again, found another coolant leak, finally fixed the last coolant leak, took the car for a drive and it still is getting hot after like 5 minutes of skidding, the only thing I can out it down to is the standard fan, I had to chop about 2 inches off it to clear the cooler pipe, still had stock shroud and aftermarket radiator. Just brought some thermos gonna install them on the weekend and see how that goes with the temps, I'm hoping that this fixes the overheating issues!
I wouldnt blame the fan for that... I would start by going back to basics! Make sure all leaks are fixed and then start working on things like the radiator... Is it blocked, is it getting airflow etc... Waterpump... Is it flowing, is it worn etc... Headgasket... is it pressurizing the cooling system and causing your leaks bla bla bla :)
I was using the GKtech fan and having issues. Swapped to my chopped out standard fan (I had to cut mine just like you did) and it has fixed all my problems.
Good to hear :yes:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
