If you didn't already have it I wouldn't buy it to start with . Better I think to have a Japanese made Nissan if you like the brand . VLs are old an thin on the ground now and I reckon the only reason you'd get an RB powered Dore is if you really like live axles . You get so much more out of R series Skylines for the money and the end result tends to be better . If I wasn't carting people around I'd look for an R32 with the RB25DE in it , I think it was called 25GT or similar .
R200 IRS , four piston brakes fall in , huge choice of wheels . Upgrades galore and heaps of spares around reasonably cheap .
Your call , A .
Just to clarify; you keep saying DE and DET, which means twin cam. The D is for Double overhead cam. A twin cam RB30 is a custom made thing, not found in any STOCK cars.
I'll assume you have a VL Turbo because you haven't actually told us what you have..
If you have a VLT with the factory motor (RB30ET), you can drop in an NA or R31 RB30E and legally drive around. This is legal because the car was available with that option.
If you have something that did not come with an RB30 from stock it will be illegal to put one in and drive it on your Ps.
Its been said before but it is definitely going to be easier to sell the turbo car as it is, or put it away for now, and buy a decent P plate mobile to see you through. 100% easier, less heartache, and you won't devalue the car you own now.
It did appear in 1 car :)
Tommy Kaira M30
Edited by 89CAL
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
