Hey all,
Wondering If I need to upgrade my injectors, Not sure what duty cycle they are running at now but I would not like to upset anything. Cockchompers at mines haven't answered my emails in months, let alone the info coming from them would be all that great. It's not in my budget right now for new ones so I'de like to pick your brains for a bit.
If I have an increase in fuel pressure I should be able to compensate for the added boost/flow.If yes what is a good fuel pressure to be running and where should the FPR be set with vaccum on/off?
Or do I need new injectors at this point? If so, I take it I need an EMS or piggy back to tune accordingly?
Rb20det parts list:
Mines ECU tuned for stock?
Pod filter
RB25DET turbo with 10psi actuator
Full 3" exhaust
Screamer downpipe
Aftermarket FMIC with 2.5" piping
Custom front facing intake plenum (more volume than stock)
Sard fuel pressure regulator.
Walbro 255 Fuel pump
The Walbro will at least keep the pressure from falling away at the top end (like the stocker would otherwise allow) which will buy you a little headroom. But realistically, if you run an RB25 turbo to about 13 psi on an RB20 you will max out the AFM and you will go pretty much to max on the injectors too. Thereby reaching the limit.
A Mines ECU is suitable ONLY for throwing from the nearest cliff into the deepest water you can find. Just get the RB20 ECU Nistuned and enjoy life. Failing that, any modern aftermarket ECU will be more than adequate.
Don't f**k about with front facing plenums. They are a shit idea. The standard one will do the job unless you simply cannot fit it under the bonnet or you cannot make the cooler piping work. There are no other performance oriented benefits to be obtained from an FFP until MUCH higher power levels (like >400rwkW).
Don't bother with an FPR. Don't need it. If you are planning on using it to stretch the capacity of your injectors, then fine, but you won't get much more out of the stockers anyway, so probably still not worth it.
Screamer on OEM turbo is full of AIDS. Just use a decent bellmouth or well made split dump that merges back in down at floorpan level.
  • Like 1
I'd suggest throwing it on a chassis dyno and log you afr's just for piece of mind.
1. you won't get an answer out of MINES in Japan.
2. If you need too (probably won't) to add a little fuel then an fpr might get you there. I don't think you will need to though. Vac line MUST BE CONNECTED!!!! Set at 47psi at idle with the line attached.
3. Honestly, if you need more fuel that a tweak of the fpr will give you then I would just turn the boost down. You might.... might be able to get away with an safc if small corrections are needed
4. Only bother with a bell mouth dump if you plan to upgrade to a bolt on turbo upgrade later.
Or if you want the extra handful of kw's, then upgrade to a nistune board, Z32 AFM, GTR/ (whichever) injectors and go for broke.
The mines ECU essentially just throw a heap of fuel, moderate timing at each cell. Also removes speed cut and ups the rev limit/air flow 'boost' cut.
Hmmm, thanks for the quite responses guys, Exhaust isn't built yet as it's a freshly swapped and running FB rx7. Going with full 3" inch and bell mouth , in case I want to slap a holset in later (why is it a bad idea to do an atmospheric gate pipe?). I know the intake actually reduces engine temp it must being so close to the engine? Mine is custom and uses only the upper half and was free so can't complain.
I have heard that mines ECU's are junk but this thing does scream much more than others I have heard... as long as it's not running lean?
the 10psi actuator will creep with added flow mods?
Can I use my mines tuned ECU with nistune?, $600 for nistune, 300- 400$ injectors and a wideband seems like quite the step up lol. Especially after buying a full adjustable suspension setup. Probably won't be doing that for some time.
Seems there are so many myths surrounding the rb20det lol.
Taking those things one at a time.
1)Atmo gate. The turbo outlet on a Nissan Turbo is one open chamber containing both the turbine outlet and the wastegate outlet. In order to do a screamer on these you have to have a divider on the dump that sticks into the outlet area to keep the flows apart. The problem is that they don't seal, so you always get leakage out through the screamer and it all sounds (and works) like shit. Screamers are not a solution for the OEM turbo. They have their place (race cars). They are pretty much illegal on the road in most civilised places, so that counts against them if you're worried about police attention.
Next part of that. If you have the FFP already, and it's in an RX7 so you probably need the bonnet clearance anyway, then fair enough. They don't do anything useful otherwise, including keeping the air more cold.
2) Mine's ECU is unlikely to run lean. More likely to run too much timing for the octane fuel you have access to (although that is a little less of a problem these days now that higher octane fuels are more obtainable). Let's just say that Mines ECU have caused more than their fair share of engine deaths over the years.
3) 10 psi actuator won't creep any worse than any other actuator. It will be fine.
4) The one thing I don't know for sure (on this one - there are other things I don't know!!) is whether you actually CAN use a Mines ECU to convert to Nistune. The Mine's ECUs I have seen have just been a factory ECU socketed with a burnt EPROM in there. So theoretically they are already halfway to the work needed to fit a Nistune board. What I don't know is if there are any other changes that would prevent Nistune from going ahead. There shouldn't be, but you never know.
Edited by GTSBoy
an atmospheric gate pipe is a certain fire risk...might sound cool but its a stupid idea.
you might have to check to see how mines have modified the ECU....if the chip can be removed easily...then you might be able to change it to nistune easy enough.
Yes I did need clearance for my hood to fit properly plus I didnt get the factory fmic, so it was a cheaper and better alternative....
Not worried about the policia, they're to dumb to figure it out here in canada Building a full stainless exhaust and building the screamer, I know it has to be divided and I can get a better seal than aftermarket along with a longer screamer tube.. But maybe I'll just do a recirc...
Nistune is a nice setup but to be able to run that shit is way too expensive at the moment. Mines will have to do for a little while.
So 47 psi for fpr with vac line?
Thanks for all the comments guys, much better than nikoclub lol.
Is this Canadian 91 octane the same as US 91 octane? If so, it's not completely terrible, but it still marginal as to whether it will ping itself to death. 93 octane is the premo stuff in the US right? That's broadly equivalent to our 98RON here, making 91MON about the same as our 95, and no-one here would run an RB turbo on 95RON. Just asking for it really.
Carbon monoxide is odorless Car exhaust is not odorless. Obviously exhaust in the car is bad, but seriously the are heaps of alive people with screamers.
And no one is arguing an internal gate screamer sounds so shit and is beyond pointless.
Edited by superben
if your tuner has nistune license and software as most others do, its about 200 for the nistune board which is all you really need
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
