I swear to god my car just likes to troll me.
On the way to work today the tweeter for one of the rear speakers has come loose.
That requires me to pull the rear seats out to get the parcel shelf out to take the speaker covers off.
Also i think my power steering is on the fritz/dead, though that isn't a big deal.
#CursedGTR
Also..
The Nismo pedals don't bolt straight on.... I'll either have to make up a bracket to mount them... Or drill into the existing metal. Will have more of a think about that today.
#CursedGTR
Also..
Well it's been off the road for a while so will take some "bedding" in to get all the small bits sorted. But - they're good little problems to have that you can fix yourself.
I'm not looking forward to the bits and pieces that my one will need sorting after being off the road for an year :(
Oh and the center console makes the best arm rest in history.
Best investment ever.
The one with the cup holder?
I've owned an R32 since 2002 and man the amount of R32 stuff i've dumped over the years that's worth money now......speaking off I should go look through that box of R32 stuff i have and see what Nismo goodies I can dig up and offer with ridiculous prices to you ;)
Fair enough. Did you end up getting a Nismo footrest?
Nah not yet. i was tempted to buy one that went up for sale a few weeks ago but couldn't justify the $$ at this point.
Ill get one eventually.
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
