Micolour Sauvic Deca - 22Nd March 2014 - Rnd 1
Proudly Presents:
Micolour SAU-Vic Deca Motorkhana ROUND 1 of the 2014 CHAMPIONSHIP
When : Saturday 22nd March, 2014 (7:30am)
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $120 per entry
Max Entries: 50 + Reserves
Entry Form & Supp. Regs: HERE
Event Schedule:
ENTRY FORM IS REQUIRED TO BE PUT ONTO THE LIST. PAYMENT IS REQUIRED TO STAY ON THE LIST.
***********************IMPORTANT CHANGES:**************************
We will NO LONGER be able to sell AASA licenses on the day. It is your responsibility to make sure that this is completed prior to the event and that you produce and supply the license on the day of the event.
If you forget your license on the day or if you do not have a license, then you will not be permitted to enter the event.
  • Please fill out your entry form clearly and in full.
  • If you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Reon Staprey Disclaimer'
  • All withdrawals will be refunded after the event. Refunds will not be given after 5pm Sunday the 16th of March.
  • The insurer of the event (AASA) has issued supplementary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
  • This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
  • A fire extinguisher is required by all entrants and needs to be bolted to the vehicle. Screws or cable ties are not acceptable.
  • Please re-read the supplementary regulations before entering the event.
  • GATES WILL BE OPEN AT 730AM. Cars need to be scrutineered before drivers briefing at 9am sharp.
  • Grouping requests: If you have anyone that you would like to be grouped with, send me a PM and I will try to accommodate.
Please support our sponsors:
Micolour – Custom Refinishing, 7 Dissik St, Cheltenham 3192, Ph: (03) 9555 8011
  • Like 1
Entry list:
1. Micolour
2. Micolour
3. Leon Stapley 180sx
4. Jake Lowry S14
5. Simon Henman HMAS-33
6. Campbell shobbrook sil80
7. Russell Cunningham sil80
8. Mathew Femino Prob GTR
9. Paul Stephenson 32R
10. Luke schulze 33 GTS-t
11. Daniel Jones s14
12. Sean Power s13
13. Jett Benson 180sx
14. Shane Janssen 33R
15. Neil Gray S13
16. Anthony Femino gts-t
17. Travis Eva S13
18. Greg Calmer S13
19. Juilette Remfrey BR86
20. Shivam Rohit 32R
21. Rhys Yeomans XR5
22. Chris Wilshire XR5
23. Marrrrrrrk Ryan HMAS-33
24. LLoyd Waldron MR2
25. Kurt Thompson S15
26. Daniel Lee 33
27. Matt borci 33GTR
28. Joshua Davey S15
29. Trent Couacand HMAS33
30. Ben Felgate S14
31. Min Chan Lotus
32. Mohammad Sharafi Falcon
33. Ahmad Sharafi 33 GTS-t
34. Micheal Bourke VK
35. Damian Hartin Exige
36. Ben Smith 180sx
37. Adam Crane Chaser
38. Joseph Canals Sil
39. Elliot Kerby 318i
40. Mathew Robins R33
41. Michael Silcock S15
42. Robert Amenta R33
43. Evan Boyact Fiesta
44.
45
46
47
48
49
50
Reserve list:
Additionally, your metal bracket must have a metal retaining clip/band that holds the extinguisher in the bracket. Brackets where the extinguisher simply clips in are not acceptable.
Be sure to bolt your extinguisher to a metal part of the body, not a plastic trim.
As above, AASA Licences can no longer be purchased on the day of the event, you will need to apply for your own licence by filling in the following form and submitting it to AASA.
http://australianautosportalliance.com/wp-content/uploads/2011/09/CLUB-LICENCE-APPLICATION1.pdf
Anyone got an idea if hose clamping the fire extinguisher to your role cage would pass scrutineering?
Couldn't find any info in the cams regs.
As above the fire extinguisher must be bolted in.
Thanks odi...
If you don't have your licence - you don't compete
if you forget your licence and cant prove that you have one - you don't compete
if you thought you could get one on the day because someone told you that you could get one on the day and drive 3 hours up to shep, left at 3 am because you worked on your car til 12am to get it ready and maxed out your credit card just to get there - guess what.... YOU DON'T GET TO COMPETE.
  • Like 2
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
