Tuned Performance Dyno Day - 22/03
no they don't... But you just keep trying to tell yourself that
Both Bodo's and mine made more power than Zeke's and Zac's and they are all running the same mods...follow the evidence :P
Cadmoon, what mods do you have?
The RB20det in my Silvia has 210hp at the wheels with stock turbo and injectors, only mod is a intercooler and exhaust.
Also it has leaking intercooler piping which is not helping the fact.
The RB20 is generally underrated , in a light car like an S13 it will leave most SR20s for dead.
I have since changed the Turbo to a GT2860rs I have a Niztune ECU, 660 cc injectors and a Z32 AFM ready to go in, should make around the 300HP atw, not too bad for a car weighing under 1.3 tonne.
All I have power wise on mine is 3" turbo back exhaust, front mount, turbosmart boost tee running about 9-10 psi, yellow jacket coils and a pod filter in a home made air box with cold air intake.
Yeah I've heard a few people say the RB20 is a good motor to put in Silvias.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
