Hi all
I am happy with the state of my tune and power delivery (263kwatw). Knock sits between 15-30 on an average day (say between 20-28 degree temp day)
The highest i've seen knock was at about 42-43, but that was on a 36+ deg day and me giving it some (prob not the best idea i know)
Using map tracer, when on full load (about 1.1 bar), I generally use L14 and L15 on the map.
Exh temp sits around 600-700 degrees when on light load areas higher in the map where timing is around 35-40 deg.
What do you guys think of the timing map?
https://www.sau.com.au/forums/topic/440251-pick-apart-my-ign-map-rb26-tune/
Making assumption that full load fuelling is right - you'd want to be in the 11.5 - 12.0:1 AFR on petrol.
L15, L16 rows might be worth revisiting, try -2 adjustment and see how things respond from knock perspective.
I wouldn't have absolute faith in the sensor outputs, you would really do well to run it on a dyno and use chassis ears (aka knock box) to physically listen for any signs of knock.
Have a good look in the L5-L8 rows, in rpm range 2500-4500. You might add 2-3 degrees there and see if it makes the thing any perkier on cruise.
Hmmm, will take that on board. I have used the temp ign adjust to dial back the entire map by -1 and doesn't affect knock reading whatsoever. have also tried adjusting +1 all round and same deal, knock reading is pretty much the same all round.
Def felt perkier in low rpm though when I went up +1 on the temp ign.
I don't have a datalogit and couldn't be bothered with mapping out the entire inj map, but will put it on the dyno to look at AFR's.
put a knock block on....i could hear knock through the headphones that was not registering on the PowerFC assuming this is what you have. what mods?
Mods are very mild.
200 CPI catco metal cat, Apexi N 1 3.5inch cat back. boost restrictor removed. Power FC
I'm tuning my wifes GTR after i scored a Powerfc off a friend. The stock maps use relatively advanced timing. i think its more cruicial getting your fuel dialed in properly before ignition...but 1 or 2 degrees here and there ain't too bad....until you can get fueling map done it looks alright, you've taken timing out in areas of deceleration/light load what were your thoughts on doing this? you can usually put more timing there.
The majority of higher knock (25-30) happens on light/mid load areas of the map. I'm taking a guess and saying the fuel load for these areas is prob on the leaner side to try maintain fuel economy while cruising.
a shame you're in sydney...could've just come over and gone for a drive with the datalogit. i'd recommend getting one if you want to start learning to tune. i think they are cheap enough these days....i bought an old one of a mate. I pulled a little bit of timing out. if you graph the values you can often see the troughs and peaks that need smoothing out. if you pm me your ign map i'll wack it into datalogit and produce the graph and see how it looks. These motors are usually quite linear....but again fueling has to match.
Edited by Badgaz
Using Pulp98 - Cas was set at 20 deg manually, then tuned. i have not physically checked this though.
EGT on full noise will be in the vicinity of 500-600 degrees. I need a second set of eyes though as I cannot be certain. the most I have seen exh temp was around 760, but that was highway driving at 110k's in 4th/5th.
Stock rb26 ecu run around 24* at 0.9bar, so youre a little advanced ign wise around peak torque area. You should get a wideband on it and look at the afrs just to make sure.
Ive heard audible knk from a rb26 and the controller only read 30's so be careful with it especially in the off to on boost areas at cruising speed in the higher gears
timing should not be tapering down with increase in rpm..should do opposite.. more advance with rpm.
you may need to pipe the timing down bit to start then ramp it in.
I did wonder why this is? is that because the duration between each compression stroke is effectively shorter?
torque drops off, less cylinder pressure so you effectively can dial in more timing
hence at peak torque you take off timing, as cylinder pressures are highest.. looking at that map, it's terrible.. there's more timing at peak torque than after peak torque.....
feel free to PM me to chat, I don't like talking about this stuff on the public forum as people like to have stabs at me.
    • Yea my thought was tighter engine when hot is more load a poor ground connection can't take. On that note, I had time to check my driveshaft verical alignment tonight, it's +2 and -2 at either end, so thats perfect and how I had set it up last year. What would be the easiest way to check horizontal alignment between my diff and transmission? I can think of a few ways but they're all complicated and I feel like I'm overthinking it. I'm hoping it's that as I can't see any other reason why I have developed driveline vibration since I put the motor back in.
    • Thank god. I thought I was the only one, nobody seems to mention this (cause nobody really goes this far in Sedan land). The car's track is 10mm wider at the rear, which explains why the rears sit a little further out for the same size wheels. There's not really many options in widebody land for sedans anyway - People will just use whatever came out of the box and then buy wheels/spacers to suit. To get it perfect you'll likely need custom wheels with custom offsets if you really want to get it perfect which is what I plan to do, but I also plan to utilize more of the inboard space for tyres at the rear... which is also something nobody ever seems to do.... OR my maths have failed me after 20,000 attempts and I'm about to make huge mistakes.
    • What colour is that?  A mate of mine went red/black on his SLR5000 tribute recently also.  And yes, also glad to see this still progressing albeit slowly.
    • found a company that makes a flat gauge face 3-d printed mounting base kit to eliminate the dished style gauges. if anyone else is looking to do the same https://www.dashfreaks.de/shop/flat-dials-holder-nissan-skyline-r34-gt-gtt/
    • I installed my link ecu shortly after. But car ran fine with stock ecu and r35 coils, just had the traction control and slip lights on.
