Hi all
I am happy with the state of my tune and power delivery (263kwatw). Knock sits between 15-30 on an average day (say between 20-28 degree temp day)
The highest i've seen knock was at about 42-43, but that was on a 36+ deg day and me giving it some (prob not the best idea i know)
Using map tracer, when on full load (about 1.1 bar), I generally use L14 and L15 on the map.
Exh temp sits around 600-700 degrees when on light load areas higher in the map where timing is around 35-40 deg.
What do you guys think of the timing map?
https://www.sau.com.au/forums/topic/440251-pick-apart-my-ign-map-rb26-tune/
Making assumption that full load fuelling is right - you'd want to be in the 11.5 - 12.0:1 AFR on petrol.
L15, L16 rows might be worth revisiting, try -2 adjustment and see how things respond from knock perspective.
I wouldn't have absolute faith in the sensor outputs, you would really do well to run it on a dyno and use chassis ears (aka knock box) to physically listen for any signs of knock.
Have a good look in the L5-L8 rows, in rpm range 2500-4500. You might add 2-3 degrees there and see if it makes the thing any perkier on cruise.
Hmmm, will take that on board. I have used the temp ign adjust to dial back the entire map by -1 and doesn't affect knock reading whatsoever. have also tried adjusting +1 all round and same deal, knock reading is pretty much the same all round.
Def felt perkier in low rpm though when I went up +1 on the temp ign.
I don't have a datalogit and couldn't be bothered with mapping out the entire inj map, but will put it on the dyno to look at AFR's.
put a knock block on....i could hear knock through the headphones that was not registering on the PowerFC assuming this is what you have. what mods?
Mods are very mild.
200 CPI catco metal cat, Apexi N 1 3.5inch cat back. boost restrictor removed. Power FC
I'm tuning my wifes GTR after i scored a Powerfc off a friend. The stock maps use relatively advanced timing. i think its more cruicial getting your fuel dialed in properly before ignition...but 1 or 2 degrees here and there ain't too bad....until you can get fueling map done it looks alright, you've taken timing out in areas of deceleration/light load what were your thoughts on doing this? you can usually put more timing there.
The majority of higher knock (25-30) happens on light/mid load areas of the map. I'm taking a guess and saying the fuel load for these areas is prob on the leaner side to try maintain fuel economy while cruising.
a shame you're in sydney...could've just come over and gone for a drive with the datalogit. i'd recommend getting one if you want to start learning to tune. i think they are cheap enough these days....i bought an old one of a mate. I pulled a little bit of timing out. if you graph the values you can often see the troughs and peaks that need smoothing out. if you pm me your ign map i'll wack it into datalogit and produce the graph and see how it looks. These motors are usually quite linear....but again fueling has to match.
Edited by Badgaz
Using Pulp98 - Cas was set at 20 deg manually, then tuned. i have not physically checked this though.
EGT on full noise will be in the vicinity of 500-600 degrees. I need a second set of eyes though as I cannot be certain. the most I have seen exh temp was around 760, but that was highway driving at 110k's in 4th/5th.
Stock rb26 ecu run around 24* at 0.9bar, so youre a little advanced ign wise around peak torque area. You should get a wideband on it and look at the afrs just to make sure.
Ive heard audible knk from a rb26 and the controller only read 30's so be careful with it especially in the off to on boost areas at cruising speed in the higher gears
timing should not be tapering down with increase in rpm..should do opposite.. more advance with rpm.
you may need to pipe the timing down bit to start then ramp it in.
I did wonder why this is? is that because the duration between each compression stroke is effectively shorter?
torque drops off, less cylinder pressure so you effectively can dial in more timing
hence at peak torque you take off timing, as cylinder pressures are highest.. looking at that map, it's terrible.. there's more timing at peak torque than after peak torque.....
feel free to PM me to chat, I don't like talking about this stuff on the public forum as people like to have stabs at me.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
