  • 5 weeks later...
This kit looks like it would be an easy plug and play kit! :yes:
http://www.mojoperf.com/drupal/node/21
I bought the RB26/LS2 coil brackets and springs from Rick at Mojo Performance recently and finished installing it over the weekend.
His brackets really are mint - saves you the hassle of having to make up brackets if you want a decent looking finish. I did the wiring myself, wasn't particularly difficult given there's a few guides out there on the net but was pretty fiddly at times. The coil cover should fit back over aswell which is good.
Anyway, recommend having a look at the above link if you're wanting to do something similar - just makes life so much easier!
  • Like 1
Some info on using the GM truck coils:
Although spark power does increase with dwell times up to 6MS, dwell should be kept below 4.0 MS, only increased while closely monitoring for timing drift. These coils have an overcurrent protection mode (probably aggravated by the non-use of resistive plug wires in this application) that will cause timing drift in the ADVANCED direction. I know of several 2JZ engines (and 1 RB) gave been destroyed on the dyno by too much dwell. This seems to be somewhat dependent on type of ECU used but it pays to be safe. 2JZ users have made well over 1K WHP at boost levels in the 40s using 3.5 MS dwell.
To be sure of quality and performance, use only AC Delco D585, GM part 10457730. Many of the replacement (Chinese copies) coils do not provide the performance of the AC Delco pieces.
  • Like 2
Great info there, and it explains a lot. Thanks.
It is also important to use resistive type spark plugs with the COP installation of these coils. Non-resistive plugs cause the coils to go into the overcurrent mode and drift/overheat.
polzin, I'll get out my diagram and post pin numbers shortly.
  • Like 2
The overcurrent conditions mentioned apply to the round truck coils with the heat sinks on top - . I think this is a consequence of mounting directly on-plug without the resistive plug wires as in stock use.
I have not heard of this occurring with other LSx coils, but then all the others do not lend themselves to on-plug mounting. This is a fortunate coincidence as the truck coils deliver almost 2X the spark power of any of the others.
So by adjusting dwell below 4.0ms would be safe and still much more powerful than stock coils?
Yes.
http://forum.nistune.com/viewtopic.php?f=12&t=2423&sid=5af4ed3fce4bc8b76abfbce93cc0eda8&start=30
Read status' s post towards the bottom regarding which coils to get and why.
Edited by Ben C34
If you're going to go to the bother of doing the swap, get the D585 truck coils.
Did you read the link I posted?
280 bucks for 8 brand new and have made 1000rwhp.
Seems ok to me. And don't have the dwell issues.
Yeah, I read your link. He doesn't mention the D585. If you research the coil conversion properly rather than spewing out something you saw on one forum you will see that most people suggest the D585 as being the preferred option. All I'm saying is, if you're going to go to the effort of doing the swap, then you may as well use the best coils possible. I paid $280 for 6, delivered; I don't need 8.
  • Like 1
Right.
How much effort is it really? A little wiring and some brackets....
I have done my research and had already done the conversion using those coils status mentioned. I don't need the most powerful coils ever, neither do you probably.
Your right, he doesn't mention the D585 coils. He does however say the ones linked do not have the dwell limiting problem that the other coils have.
Quote:
Lots of testing has been done on all the variants and this one does not false fire (effectively uncontrolled added advance) at higher dwell levels like the others.
Seems like the sensible choice. Even if it's not the most powerful.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
