Was gonna cruise down kingston se way next week in the rs4s and camp on the beach/sand. I've heard and read on numerous occasions that it's a nice beach to drive on because the sand is good and firm. I'll be honest, I haven't been near here before so I dont really know what to expect.
Has anyone else ever given a bit of awd action of this respect to their stagea? Any tips/advice? How was your experience?
Obviously you wouldn't even try to drive near the water's edge and i'm not about to thrash dunes like I'm a Dakar rally champ.. Just away from the carpark zone enough to be nice and private.
I'm also conscious of the fact that it's rwd bias and not full time awd..
Any thoughts?
https://www.sau.com.au/forums/topic/440498-awd-action/
If you turn the awd lock button on you will get 50/50 front and rear at low speeds but if you don't have huge knobbly tires you will just get 4 wheels spinning! And if it were my car it would soon be sitting on the sills...
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227931
no locked diffs, you will get stuck,
its awd not 4wd,
that being said... camping rocks
actually 99% of 4x4s don't have diff locks. and in general you don't need them for sand driving.
your biggest issue would be lack of clearance and smooth road tyres. if you could keep to the hard packed stuff I can't see it being an issue. Just make sure after you give it a damn good clean to get the salt water off
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227940
Mm.. the no lock diff does have me a bit worried and I am aware of the difference between awd and 4wd. Its at standard height but the tyres are indeed for road use.. but they're brand new.. just didn't want to be out of view of the car in the carpark (although that doesn't matter so much when you're asleep :P).
Also depends on how the conditions are and how I confident I feel at the time
Edited by staglover
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227948
the no diff locks would be the thing to worry about the least. the no low range would be more my worry.
Just make sure you take it easy and limit wheel spin. Keep it to the firm stuff and you will be ok. Its not different to all the subarus you see on the beach.
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227950
what about manuals with the torque split
Are you referring to a manual torque splitter? My stag is a manual, dont have a torque splitter intalled though.
Stags would also be heavier than a scoobie I would suspect..and not fulltime awd like its japanese cousin
Edited by staglover
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227961
RS4S has no lock button Bob.
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7227968
thats what i mean. uses the R33 system.
well im interested in hearing how the stag goes on sand, it just reminded me of this thread recently.
http://www.skylinesaustralia.com/forums/topic/439613-stagea-stuck-on-dirt-s2-wgnc34/
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7228170
sorry maby i mean something else, i think it cant lock left to right or something. you can trip them up anywho.
Diff locks are what stops left to right, but as I said 99% of 4x4s don't either. It's only very serious modified trucks that generally have left to right lock.
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7228179
Interesting.. I definitely will post the results if I do end up on the sand. meanwhile, id love to hear more about peoples thoughts on the matter. So far I'm split 50/50 whether or not to do so. Ive also seen people do beach driving in commies/falcons and the like.. even corollas at silver sands.. Edited by staglover
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7228433
Dont see why a stagea wouldnt go very well on firm or even slightly soft sand. As people have said clearance woukd be the issue.. diff locks on sand can help but they can also cause issues. Huge muddies arent needed, the more tread in contact with the sand the better so even dropping the psi like a 4wd'er would help.
Smooth throttle, brake and steering inputs as well as using a bit of momentum if needed and you should do pretty well.
Or create some kind of crazy patrol/stagea hybrid...
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7229574
that sucks man.... lets do an RS4-S beach camping cruze!!!
Im so in right now :D will need at least 3 weeks notice though for work which makes it kinda just 'hope for the best' haha. Not saying we shouldn't though
https://www.sau.com.au/forums/topic/440498-awd-action/#findComment-7236798
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
