hi guys,
recently i purchased an r33 gts of a random. he "says" the car was running but as i got it, it didnt start and still doesnt. the positive terminal from the battery in the boot snapped off so he used a speaker cable to connect it ? im not sure if that has shorted anything out or stuffed anything up but i went to the wreckers the next day and purchased a whole new one, connected it up but still no start. i opened up the coil packs and spark plugs, they were all rusted and stuffed so i replaced them too nut still nothing, the car turns over but doesnt fully start! i sounds like it wants to but there is no spark so im thinking it is an electircal problem. can someone please help me.!!!
https://www.sau.com.au/forums/topic/440686-33-gts-wont-start/
just curious how much doe s a R33 GTS non running go for these days.
re the issue, start with basics
for a car to run you need spark, air and fuel.
check you have spark at each plug by removing it plug back into coilpack then hold close to the block and have some-one crank it, see if you get spark.
then when you first turn ignition (make sure it's quiet and no stereo on) on can you hear a small hum from boot area, ie can you hear the fuel pump working?
if not pull the fuel filter and crank does fuel come out?
past that get a lube mobile round to have a look?
Where do you live?
You say the car sounds like it wants to start, but there's no spark... Generally if it sounds like it "wants to", then there is spark in at least some cylinders but its not catching enough to become self sufficient.
From your description it could be anything, low voltage, buggered ecu, buggered coil pack loom, buggered CAS...
+1 to martin's suggestion of a mobile mechanic... otherwise you could be throwing a heap of money at replacing parts which are fine... (Alternatively if you have a mate with the same car, make it a doner car for a day till you see what fixes it)
I had the exact same problem but on a honda accord. Car sounded like it wanted to start but it just wouldnt. It ended up being a fuel pump. The fuel pump in the honda was under the car in the fuel tank, it was the worst job ever trying to replace it.
Luckily the fuel pump in your skyline is in the boot near the battery I believe? If it is in the boot, its an easy job to take it out. I dont think a fuel pump is expensive, I think around the 100-200 mark.
I reckon have a look at the fuel pump before you look at replacing ecus.
Have you checked fuel pressure?
Why do you think it's the ecu? That would be my last thing to swap.
What do you mean sounds like it wants to start? It fires or just cranks fast?
Is there spark when you remove a coil?
Seems like you are just taking a fairly random approach to this, and I recommend you pay someone who knows what they are doing as it will cost you less in the long run.
Why did the guy sell it?
ive done everything now, bought a new coil pack, checked to see if there was a spark and there is with every spark plug, bought new spark plugs, new cas, new ignitor, replaced all the relays and fuses.
there's a little light next to the steering wheel on the left, it doesn't flash or anything but im thinking maybe the guy who I got the car off installed a a mobiliser and didn't give me the button for it so it wont crank over, the car has central locking so thats another thing
someone please help i dont know what else to do, and Im taking it to an auto elec on monday but to save money id like to fix it myself
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
