Racv-Aomc Classic Showcase 2014 And Japanese Motoring Show
With one of my brief internerd search's I came across this.
Judging by the layout map, it looks good.
RACV-AOMC Classic Showcase 2014
and Japanese Motoring Show
And the link... http://www.aomc.asn....u/B&Eshow14.htm
It really looks like a fun day out and dead cheap for a look around and enter.
I'm thinking of washing the car and entering and having fun. Anyone else keen?
If your there and see a yellow Evo 7, come and say "hi" :)
looks like a good day. For that price its hard to say no to entering. Will force me to wash the car too :P
wait... does "Classic Japanese" mean older than, say 1990 or something?
"Best Japanese Rotary powered Sedan" That's a bit narrow isn't it? I guess you could put your F&F spec skylines into "Best Japanese Open Sports Car"?
Edited by bucket_boy101
Hopefully...no. What with RX2, RX3, RX4 and Cosmo's.... (RX8's have 4 doors but classic?!?)
It should be a good day out, and i'm hoping the Evo can enter, and if the EVO gets in then ANY Skyline should be a shoe in for entry. :)
I was JUST about to ring them haha, guess I'll just rock up?
Anyone from the south east want to go together?
Yeah, what time you leaving? Im coming from clayton
I'm from Mordy.
Not sure what time but maybe try get there at around 9:15-9:30? To try get a good spot? haha
I may or may not join this convoy...i will however be parking in the Toyota section with the other toffs, away form the Nissan peasants...
Might have to miss out on this one unfortunately, moving apartments this weekend. Will definitely go to the American car show in April if anyone else is interested in joining me :)
http://www.aomc.asn.au/USAshow14.htm
I personally prefer classic American cars the most.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
