Hi Guys,
I recently converted my NM35 from the factory front brakes to calipers and rotors from a R34 GT-T. I used the factory lines and removed the restrictors from the calipers.
After the conversion the brake bias seemed to be hugely out, I assumed this was due to the master cylinder not being able to keep up with the front brakes and fitted a BM50 from a S15, this improved pedal feel but the bias is still completely off.
e.g. after a normal around town drive the rear rotors would be 70 degrees while the fronts are 40, after a hard drive the rears will be 150 degrees and the front 70. The front rotors are glazed while the rears look like they are doing all the work and have a nice wear pattern.
Im beginning to wonder if removing the restrictors in the calipers is what is causing this problem.
Has anyone else had this problem, and what did you do to fix it ?
https://www.sau.com.au/forums/topic/441062-m35-brake-bias-after-r34-conversion/
Sounds like you haven't bed the front pads in correctly.
I had nice front bias with the sumitomo's, running the factory master and stock rear callipers.
I have now too much rear running the Brembos. You can change the bias using pad compound to some extent I found.
Well, for a start, the Silvia BM was the wrong direction. They run a higher level of rear pressure before bias is stabilised. Nissans run 0.4 rear to front as a rule I've read.
I can't say I have the same issue. I have r32 gtr calipers on mine, with restrictors removed, and it brakes fine. Had it on the track, and didn't notice any terrible front or rear bias.
I have been for close on 2 years running the exact same setup as you are running with absolutely no bias issues.
Mine pulls up hard & straight time after time with excellent pedal travel & feel.
The "restrictors" you speak of; are simply the double flare brake line seats for the GT-t OEM lines; they do not do any kind of restricting at all.
Are you absolutely sure you have the calipers on the right way up (bleed nipples at the top) and have introduced no air into the system, or the ABS module?
Sometimes silly things can bite you on the arse; you would be shocked at how many peolpe have intalled the Sumitiomo calipers upside down.
What does it feel like when the bias is not balanced?
Aren't the rear calipers getting hotter than the front because the rears are smaller? Isn't one the reasons of going larger calipers is that they won't suffer from fade as quick as the stock brakes will?
Did you measure the temperature of the rears before you did the conversion?
Measuring the temperature of the brakes will only waste your time, the rear disk mass is much less than the 34gtt disk and will heat quicker, it will also cool quicker. (as Matt was getting at)
I would be looking at your pads, what compound are they? What brand?
It pulls up straight, but the pedal is very light for around half of the stroke before the brakes start to drip fairly hard.
Yep, made sure the calipers are the right way up. I was actually suspicious of the problem being air in the ABS module. We have bled the system around 3 times now and each time get some air out.
I'll vacum bleed the system and see if that improves it.
The main reason I think the bias is out is because I can lock up the rear brakes on it, easily. The wear on the rear is also quite pronounced while the fronts just look glazed.
Im going to vacum bleed the whole system and look in to getting some decent pads, it currently just has whatever the local repco had on the shelf (probably crap)
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
