Want to buy: All to suit R34, rb25det neo.
Neo engine cover
Drivers seat belt
Drivers side wiper arm
Headlights - these need to be in good condition with no snapped tabs, preferably standard without H1 conversion
Manual shift stick - from the gbox into centre console, the one with the thread
Manual gear shift surround/trim + boot
Preferably located Perth, but will cop shipping if I can't get it anywhere here.
Cheers.
https://www.sau.com.au/forums/topic/441319-wtb-various-parts-for-r34-gtt/
Neo engine cover - I'm looking for one someone has collecting dust, not one a shop is trying to fob off on me for $150. They are a piece of non-essential plastic, I'm not paying crack prices for it.
Drivers seat belt
Manual gear shift surround/trim + boot/gaiter - I need the gaiter, but will buy entire trim if it gets me the stock one.
Edited by sleptema
Hi Steve,
I can help with a brand new surround & trim, following is a link for the listing on our website:
Genuine Nissan Gear Boot & Surround - Nissan Skyline R34 20GT / 25GT / 25GT-4 / 25GT-t / GT-V (05/1998 - 08/2000, 5spd M/T)
Regards,
Andrew Sullivan
Kudos Motorsports
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
