  • Replies 42
ill take the bonnet for 600 in 2 weeks if still there for sure
just need to save a lil more
Edited by gttiwanna
Hinges and the bonnet latch mount are available from Nissan and aren't all that expensive.
Wouldn't say they were cheap either. $255 for a set of bonnet hinges.
Edited by Nooba
Thanks for that, as stated I can also supply hinges free of charge. They appear to modified gtt hinges that were used on a r324. Would probably fit a r34 also.
I do have a spare but it's not included in the price of the plenum. It has the water temp sensors and crank case vent valve? but not the cast piece that fits to the radiator hose.
Of course just let me dig it out and I'll let you know a price. Just to let you know I did have someone interested in it last week but I haven't herd back from them.
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
