I've recently built a rb25/30det slapper and I'm having troubles with the timing, I set the crank to tdc and set the cam gears to the marks and when I check it with a timing light it shows it roughly 40-50 degrees off tdc and I stuffed around with the cas and turned it all the way and still got 30 of tdc what could be my problem?
I have a tensioner above the water pump and a idler on the lower
https://www.sau.com.au/forums/topic/441992-my-rb30det-build-timing/
You need to put a plug lead on to number one coil connect it to the plug and connect pickup to that. .
Disconnecting the tps should lock the timing the ecu is putting out to 15. It does vary to maintain idle, it varies a lot if the idle is high or unstable.
Do you have nistune or consult to view what timing the ecu is putting out?
With the light I just put it on the coil signal wire and I had a mate with a 25 and we tested his and it was fine. I'm just running it with a stock ecu until I know everything is fine because I was $1000 last time I took it for a tune, I have a haltech platinum
So it's meant to be 15° btc
And the rpm is meant to be 650?
And do I need a loop wire or is using the wire on the coil pack plug good enough?
yes
yes
no - buy a $5 spark lead and do this (not my photo):
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
