  • Replies 42
UPDATED PRICE LIST
$150 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
$180 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
$10 Alloy BOV Bung/Plug
$10 110L/h Fuel Pump that fits in stock position
SOLD 2x Falken Azensis RT615 225/35/17 with around 3mm tread
$40 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo
$40 BRAND NEW OEM Rear Main Seal & Spigot Bush for RB2xDExx motors - 12279-5L310
$200 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece
$20 RB25DET S2 Factory dump pipe & down pipe
$20 RB25DET/RB20DET Factory Manifold
SOLD $40 RB25DET S2 AFM
$20 RB25DET S2 Stock Blow Off Valve
$10 RB25DET S2 Radiator
$10 RB25DET S2 Fan Clutch
$50 RB25DET S2 Stock SMIC & Pipes
SOLD $200 RB25DET S2 ABS Diff - minus ABS sensor
SOLD $20 RB25DET S2 Stock Anti Roll bars / Sway Bars (back)
$20 RB25DET S2 Stock Anti Roll bars / Sway Bars (front)
$10 RB25DET S2 Rubber Intake Pipe
$10 RB25DET S2 handbrake boot & gear boot (1x OEM 1x Aftermarket)
$10 RB25DET S2 HICAS Rack & Tie Rods
$10 SR20DET S15 Radiator
Keep seeing your npc clutch plate for sale, wondering if ill save much getting the plate from you and the rest jew from npc, as ive been wanting to get the npc carbotic 10" clutch to replace my slipping one...
Call up NPC and speak to Doug, OR alternatively, call Scott at Western Clutch at St Mary's and ask if he can sort you out. He uses the same pressure plates as Doug uses in his NPC clutch kits but sets the clamp only at ~1700kgs so the car is more driveable where as Doug goes for the moon.
Scott tested mine and it was over 1900kg of clamping force making the car a bucket of shit to drive and he reconfigured it to around 1700kg.. the car drives like a Yaris now after he curved my new clutch disc.
Il take the rubber intake pipe.. pm me payment details and postage costs.
Cheers
You sure you want it? Postage would be as much as the item lol
UPDATED PRICE LIST
$200 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece & no snapped studs
SOLD $180 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
UPDATED PRICE LIST
$20 RB25DET S2 Stock Anti Roll bar / Sway Bar (front)
SOLD $150 Yellow Jacket Coil Packs for RB25DET S1.2/2, Stagea Non-Neo RB25DET (7x coils) - happily held 1.2 bar of boost
SOLD $180 RB25DET S2 Turbo - no shaft play, exhaust wheel in one piece & no snapped studs
  • 3 weeks later...
SOLD $150 NPC 400kW Clutch Plate - Barely Used, worn 0.03mm / Will fit any RB
Yezz.. sold clutch & rear main seal :)
SOLD $40 BRAND NEW OEM Rear Main Seal & Spigot Bush for RB2xDExx motors - 12279-5L310
$10 RB25DET S2 Factory dump pipe & down pipe
$10 RB25DET/RB20DET Factory Manifold
$10 RB25DET S2 Stock Blow Off Valve
$40 posted on the oil feed line?
Waiting on one dude to pick it up, if he falls through its yours for 45$ posted :)
$40 BRAND NEW Braided Oil Feed Line for Stock RB25DET Turbo ~ PENDING
Will take everything here for a 6 pack of beer:
SOLD $10 RB25DET S2 Rubber Intake Pipe
SOLD $10 110L/h Fuel Pump that fits in stock position
SOLD $10 RB25DET S2 Factory dump pipe & down pipe
SOLD $10 RB25DET/RB20DET Factory Manifold
SOLD $10 RB25DET S2 Stock Blow Off Valve
SOLD $10 RB25DET S2 Radiator
SOLD $50 RB25DET S2 Stock SMIC & Pipes
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
