And learn some more new names - if I can...
Many thanks to all the tremendous pics from all the photographers out there in Brian, Milan, Chris, Ciaron and others.
And thanks to all you guys who came, sold and conquered to make the SAU empire expand.
Trivia...
* A vendor found it hard not to laugh at haggling by an 'asian' and a 'wog' over the same item
* Sylvia was being eyed off by the cops when they arrived
* Sylvia driver took off whilst cops were occupied with Ciaron
* Cops enquired about how your lovely cars were imported
* Iron Chef was 'implicated' as the person responsible for bringing in some of the best examples
* R35 has never been driven such a short distance by a new person behind the wheel
yea, but didn't get their numbers xD need to ask John something relating to the bonnet strut bootlid mod :P
John is my mate with GTR 342, I can find out whatever you need. Send me a PM.
Interesting trivia there Terry :)
Loving all the pics people!
Edited by Sovereign337
Maybe next time you will be able to use more than 1st gear Terry ;)
Also thanks to all the photographers for the nice photos of the R35
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
