Hi guys.
On the weekend I did the cam belt, tensioners + water pump on my gts25t with brand new 'genuine' Nissan parts. All went smoothly and the car was running fine till this afternoon + a bit of 'spirited' driving caused this:
DSCF0400
The crack runs about 240degrees around the shaft and there is a chip out of it as you can see.
My question is obvious, WHY?
Was my alternator belt so tight it caused this? I didn't use a belt tensioner but I know it wasn't overly tight and the belt is in good condition as is the alternator pulley.
Or was the water pump a faulty product? Can anyone confirm if it is 'genuine' based on this number?
DSCF0401
I just want to get a heads up before I go back to the seller.
https://www.sau.com.au/forums/topic/442422-water-pump-failure/
Water pump bolts were torqued to spec. The belt wasn't tensioned as I don't have a belt tensioner, but I was able to give the belt a 1/4 turn on the top and bottom.
It took less than 30kms for this to happen.
Would it have a chip out of it like that if the belt was over tight?
I'd classify myself as an 'advanced' DIYer. First time doing a cam belt change but not the first time dealing with auxiliary belts.
Thanks, that puts it in perspective. Some guys have absolutely no clue and do things up mega tight.
personally I always err on the side of loose, as you will know if it's too loose (it squeals) but too tight is harder to know.
I don't think many people use a tension gauge.
The thing is as you would know if you are super strong you can get a quarter turn on pretty much any belt no matter how tight it is. Have you been working out lately :)
hmmm that makes it interesting then
why did you put quotation marks around genuine? Was it not from a completely reliable place or second hand or something along those lines?
That might be my only concern now. If bolts were done up right, and sounds like the tension was O.K (without knowing how hard you were turning it to get 1/4 of a turn)
I have my own 1/4 of a turn method that I've been doing for quite a while now on alot of different belts (heavy machinery mostly) and usually is pretty good on your standard v-belts. But as said, I've been doing it my way for years with no issues, but your way and my way might be the same in theory but completely different lol.
Haha, that's a definite no on the working out! My arms got tired after just doing this job.
The parts were from a Nissan dealer, more specifically from here:
http://www.trademe.co.nz/Browse/Listing.aspx?id=715037326
I put quotes around genuine as the cam belt came in a package labelled 'A31 RB20DE' and the water pump is marked '3Y07' which is different from the old one. I know neither of these things are necessarily bad and they might both be genuine and correct parts for an RB25 so hopefully one of you guys can confirm this for me so I can put that one to rest?
When you stripped it down to inspect the damage, was the alternator belt still sitting properly in the various pulley grooves?
Hadn't tried to climb off or anything?
I have seen pumps go like this previously, but they were no-names.
If you break the pump right through at that crack I think you'll be amazed how thin the metal is.
Yeah mate all belts were in line and are undamaged, no nicks out of them or any cracks.
Comparing the old pump with the new, the new one does seem to be a bit lighter and not of the same quality. That could be my imagination telling me what I want to hear though.
Saw this failure on my mates Mazda after we put a new wp on, we went with manufacturing defect but would be interested in other thoughts. (Mechanic by trade so I'm confident in the workmanship :))
I'm sending it back to the Nissan dealer for them to have a look. I'll let you know what they say.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
