Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine
This is Power!!
- 38" Bore, 98" Stroke
- Each cylinder displaces 111,143 cubic inches and produces 7780 horsepower
- 1,556,002 cubic inches
- Maximum power: 108,920 hp at 102 rpm
- Maximum torque: 5,608,312 lb/ft at 102rpm
Might stuff one of the under the hood of the 180 for a bit more mid corner low rev chasis twisting torque. What do ya reckon the labour rate would be for the converion, given it weighs only 2300 tonnes.
https://www.sau.com.au/forums/topic/44248-the-most-powerful-engine/
Presenting the most powerful engine in the world, a product of Aioi Works of Japan's Diesel United, Ltd. Strickly a boat engine, this moster of epic proportions is primarily used to power super tankers and other large boats of that nature that require a single engine, single prop set up. The main advantage of an engine like this is that is all on piece, no need to have complex differential linking engines together and it is very thermodynamic, i.e. it turns more combustion energy into kinetic energy, as opposed to just heat. It is actually twice as efficient as a car's engine. But it still gets poor mileage, guzzling 1660 gallons of fuel an hour.
CHECK OUT THE ATTACHED PIC'S :crazy: :cooldance:
This is Power!!
anyone got pics of the turbo!!!
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
