After some advice, my car needed an engine rebuild gearbox rebuild n a new clutch, so I ordered in a new nismo twin plate copper mix comp spec clutch from rhd in japan. But when the mechanic went to put the clutch in turns out a previous owner has converted it from pull to push type, an the clutch I got was a pull type (car is a 33gtr). Wot are the options? Don't really want to freight the clutch back to japan an freight a new one in even if rhd were okay to do that.
  • Like 1
https://www.sau.com.au/forums/topic/442496-so-i-got-the-wrong-clutch/
To run an expensive push type clutch.
You mean inexpensive? As pull type clutches are more costly than push types.
Or you mean it's only expensive because you have to do the conversion and then by the clutch on top? :)
Expensive as in a $2k clutch, but yes, I'd imagine pull types might have been more expensive outright purchase and servicing wise. Please note the time stamp hahaha.
I remember seeing (I think) ORC clutch kits with the converter, no idea if they ended up costing more than the equivalent pull type.
If you get the right kit from new it will come with the correct bear etc
Company's like OS giken and others only make push clutches, so sometimes to run a really serious clutch you might need to go push.
I've changed between the 2 many times and the OS Giken pull to push kit is literally a few bolts and a different fork.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
