450kw and 127mph? u sure that leak wouldnt have lost you power? i run 127mph and im only just over 500hp on 24psi, only peaked at 23 for the day though.
i don't know mate.
The only way to find out would be to run again
Awesome afternoon. The Evo guys loved it. I finally got to run my Evo for the first time & managed a 12.30 @114mph.
Does anyone know what Phil's best time was in the R35 GTR? I need to pass the info on for an internet article.
Looking back at my videos, I'm starting to wonder how I would have gone if I'd let the car get anywhere near redline...
I just have too much mechanical sympathy I think.
only be way to find out
Back to Willowbank the legume (yes, legume) goes for rev limiting thrashing
Yep, still got a free pass that expires December from a time when test and tune was rained out.
Bought an open face helmet for $40 yesterday since the full face one got too hot on Saturday.
I'll go back out as soon as Sneaky Pete decides to run his car.
well Im going back this Saturday
  • Like 1
Not I :(
I have however ordered some slimline engine mounts to fit my 2.5in intake and 2.5in incercooler piping that have been sitting in the box since xmas. Might as well turn a gearbox removal into a positive right?
Not I :(
so what happened exactly Mike and what times you run?
Not I :(
Engine out?
  • Like 1
Got to the end of the quarter, slowing down, tried to shift from 4th to 3rd and it wouldn't go. Perma stuck in 4th. Was working my way into the launches having never been on MT's before. Didn't feel like I had a single clean run unfortunately. Only made 1 trip to the timeslip booth and collected 2. 1 said 12.5 @ 123, the other said 17.5 at 77.
Wideband saved me again on that run. After burnout I noticed lean. Kept a keen eye on afr's, sure enough under boost was too lean. I had figured the boost feed for FPR had come off, and I was correct, pulled up to check and it was flapping in the breeze.
Every modified boosted car should have a wideband IMO. Cheap insurance.
Engine out?
Nope not engine out. Will sling it and slide the mounts out and install the slimlines :P
100% agree on that ^
Is on my to do list as well (EFI also recommend it too)
so many more parts, so little spare cash............quick off to the for sale of parts thread
Hey mate, where did you get your helmet from. And how did the horse run.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
