For sale:
Various r34 GTR/rb26parts
Power fc w/hand controller 550 ono ----tuned for t04z/type B camshafts/840cc injectors making 340awkw on 20psi.
Sard - 840cc top feed injectors 500ono
R34 Gtr brake master cylinder and pedal assembly 300 ono
R34 GTR engine sump/front diff assembly. Offers
R34 GTR rear diff with abs offers
R34 GTR complete interior / all panels minus roof lining, front seats and rear parcel shelf. Selling panels individually or in pairs. Offers
Custom surge tank with 2 bosch 044's with all fuel lines and fittings 600ono
Turbosmart Bov with intercool pipes to suit standard gtr frontmount. 200ono
I am up for swaps aswell but prefer cash. Located Chermside brisbane. Pm for photos as there is so much stuff.
https://www.sau.com.au/forums/topic/442603-r34-gtr-parts-brisbane/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
