I was not born in the computer generation ,sorry,Thanks Greypearl.
Um.....it's the computer generation we usually have the most trouble with not being able to form readable prose.
The rules for written language are quite simple.
1) Have an idea you need to convey.
2) Put together words to convey that idea. Use just enough words to correctly convey that idea, then put in a full stop. If one sentence won't cover the whole idea, then start again with a new sentence for the next part of the idea.
3) If you have multiple ideas to convey, repeat the above for the next idea and so on.
4) For breaking up major different ideas, press the enter key a couple of times so you get a new paragraph.
Also, numbered lists like I have used above can be convenient ways for people to address individual points you are raising. They can refer to your numbered points. It's great.
  • Like 1
Thanks GTSBOY so simple when you know how
1) Need to know which are best and why BC'S or Bilsteins.
2) Bear In mind that my car will probably never see the track.
3) Cost is a factor,Cheers Greypearl.
Edited by Robert Knight
  • Like 1
If you want some help making a decision go to the top of this page to the "pinned" topics and read " shockabsorbers 101" by SK.
SK has designed suspension set ups for Skylines and Stageas and I have followed his plans for my Stagea :
Bilstein shocks front and rear (but with Tein springs - missed out on the group buy) and heavy duty anti-roll bars.
I also have adjustable castor and camber arms but set fairly conservatively for the street. I ran 3 deg neg camber at the front and 1.5 deg at the back with my slicks which was great on the track but chewed out my street tyres so I toned it down a little to 1.5 deg front and rear. Tyre wear has gone down but my heavy wagon still handles pretty well on the road.
After maximising the caster (we can never have too much caster on an R32/33/34) I would have gone for 1.0 to 1.5 degrees negative camber on the front and 0.75 to 1.25 degrees negative on the rear. R33GTR are predominantly understeerers due to the ATESSA calibration and HICAS programming, so I also find around 2 mm toe out each side, front and rear, to be beneficial.
Having sorted the wheel alignment the choice of dampers is a pretty simple one, I have found Bilstein work well on R32/33/34's due to their sophisticate valving. There's about 300 or so kits utilising Bilsteins in Skylines, Stageas and Silvias running around from the old Group Buy days and the guys seem pretty happy with them. Depending on the budget non adjustable, single adjustable with or without remote canisters or triple adjustable with remote canisters.
For non adjustable I'd suggest Kings springs (Lows NOT SuperLows) as Redranger in their infinite wisdom discontinued all Whiteline springs. The Bilsteins I do have my valving specs and come with additional circlip grooves so the cars ride height can be selected prior to fitting them. For R33GTR's I never go lower than 355 mm on the front and 345 mm on the rear (centre of wheel to guard as usual) as the ride deteriorates and the suspension geometry is not designed to operate at lower than height.
If finite on car height adjustment is desired then Eibach are the best spring choice. They require the addition of what we call "coil over conversion kits" to the Bilsteins.
Always remember that swaybars are by far the best value handling upgrade, road or track. You have my email address if you want to discuss.
Hope that helps
Cheers
Gary
  • Like 1
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
