Greetings Folks.
I have recently picked up a 1993 R32 sedan with a RB25det Neo conversion that was 99% complete.
I just need a couple of things to finish her off and get it back on the road.
I'm sure this topic has been covered thousands of times, however after extensive use of the search function I still can't come up with a definitive answer.
What accelerator cable will fit the conversion?
I know a R31 will not fit, I've purchased 1 and it is way too long.
The motor has a godspeed front facing plenum and a 80mm aftermarket throttle body.
If there is a link to a thread could someone please provide me with it?
Thanks in advance
Cody
https://www.sau.com.au/forums/topic/443081-r32-sedan-rb25det-neo-conversion/
This has nothing to do with whether it's a Neo conversion or not. My Neo in my R32 uses the original R32 cable, because the throttle body is in the same place!
did you read my post at all?
it has everything to do with a Neo conversion, as it is a neo conversion in the car.
also congrats to your 32. If you had of actually read my post, you would see that I have a front facing plenum installed. Therefore the throttle body is no longer in the same position.
if you want to be a keyboard warrior mate, I suggest you go jump on boostcruising.
Lol.
How does the fact it's a neo matter?
It's the different plenum that has caused your cable issue. Not the neo.
I concur this has nothing to do with neo conversion and everything to do with forward facing plenum conversion.
All the best figuring out your terribly difficult and confusing issue.
I did help.
Don't confuse the neo conversion with the ffp conversion.
Search what cable people use with a ffp.
Or better yet ditch the ffp and run the stock one. Then cable issues sorted.
Edited by superben
This is relevant to my interests. I presumed the standard cable would be long enough to reach. Any info on this appreciated.
Just measure up how long you need go down to pick-a part (some auto wrecker) and find one that approximates.
I've done a neo conversion with R32 rb20det computer, what else needs to be done that you haven't got to yet?
You will need either an ECU that can control the VCT or a window switch to do so, the ignitors and the CAS also won't plug into the stock loom, or have you transplanted an R34 loom?
And just cause i was being helpful i looked up the maxima i got mine from and it was a 95-99 model, was exactl same fittings as an r33 but longer
For future peoples that search for this...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
