This has probably been covered before, but I thought I would start a new thread for some fun especially with the popularity of E85 these days.
So, post up times of completely unopened OEM RB26 GTR's 1/4 mile times:
A quick search gives me:
XRATED: - [email protected] (R32, 396rwkw)
Tynago: - 10.7@137 (R33)
DVS Jez: - [email protected] (R32, 402rwkw)
GO!
Sorry to get off topic here a little. Isn't that gtr still running a H box. Does anyone know.??? I've seen the attachment that makes it shift that way but I just can't remember the name. Help.
No, [NITTO] runs an OS88 Sequential 6-speed.
You are referring to the Ikeya Formula Sequential Shifter that can be used with the OEM H-Pattern:
http://www.nengun.com/ikeya-formula/sequential-shifter
GO!
wow... that was a long time ago..... that was before 98 was even available at the pump in Tassie, little own E85! ha ha ha
... well hoping to run a little quicker next year with a new engine (and everything else).
Cheers
Justin
Yeh I did 11.30 @ 127mph stock engine stock head 98 octane with t517z turbos
XKLABA did 11 flat I think stock engine stock turbos
11.3@125 stock every thing in full weight R32
11.1@123 new HG and big ends bearings on drag radials with 293rwkw
Would still be interesting to see the results, Simon.
Thanks for the info guys.
I would think that with these engines getting older (25 years now), that it would be hard to beat those previous times (10.6's!)
My 33 has run 11.5@126mph weighing 1760kg with only -5's, ecu, fuel pump and injectors on E85. Bigger cooler and exhaust should help.
I might give it a crack while I get my built engine ready and see what happens :D
Last year on a unprepped runway (Racewars) I did a high 10 @ 136mph with approx 640hp at the hubs
Same runway this year I was doing similar times and trap speeds but with a passenger and a full tank on fuel with around 700hp at the hubs revving to 8000rpm
With a few more revs and less 150kgs of passenger and fuel I would hope I'd be around 140mph+
Might give it ago when the drags open back up over here but the gearbox may not like it :yes:
Edited by SimonR32
I've often thought about getting a good condition unopened 26 and slappin on all my 'big' bits and seing just how far it would go. Willall did it back in the day, but with a freshened up 'to stock specs' engine... so it doesn't really count.
It'd be cool to run 9's/140mph+ on an un opened engine in a true street GTR. We'd allways be at a disadvantage to stipped out auto GTR's though.
J.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
