Hi everyone, first time posting on this forum so take it easy.
Without thinking i've removed the cam angle sensor of my neo without making any marks. And making it worse i've turned the engine over a few times with the sensor off.
I was just wondering how serious this situation is? the pin/input shaft that going into the end of the cam shaft looks like it can only go in two ways. So is it a 50/50 change that it will go in the position that it was previously in before i took it out? or will it be 180 degrees out of its original position and will send the wrong signal to the ecu.
how noticeable will the effects be if it were to be in the wrong position. will the fix be as easy as rotation the pin/shaft 180 degrees?
Any help appreciated
Thanks. :yes::cheers:
https://www.sau.com.au/forums/topic/443810-cas-cam-angle-sensor-help/
I think you need to get the timing marks lined up so its on TDC, then slide the Cas in so the half moons join, then hopefully theres a mark where it was sitting or else its about half way and need checked with a timing light
Edited by AngryRB
oky thanks for the reply man!
This mark you mentioned where are they located? Im unsure of what position the timing marks were when i removes the cad, so i was wondering if i did put it back at TDC theres a chance it still maybe in the wrong position.
It only goes in one way, the slot is offset, line up the bolts withthe old marks, and check with a timing light
Exactly this. Doesnt matter where the cam is, as long as you have the half moon (these sometimes break but sounds like yours is there) you can slide the CAS over that, rotate it to line up with the bolt holes, do the bolts up loosely and then get a timing light and set the timing
Neo doesn't use the spline and half moon system but can still only go on one way.
Whether you have marked it or not, you still have to set timing with a light.
The marks are never going to be good enough.
  • 3 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
