Ohhhhhh not long now, very excite. Prepare for rain because im washing the blue beasty on the friday so im predicting rain on saturday. Got the day off work so am 100% gonna finally make a Tech arvo :P
Hey Terry,
Gonna have to pull out. Family arrangements decided to come up last minute. Hope you guys have fun, will be a blast.
I am disappoint!
You could have tried to sell Adam my old turbo :P
ADDENDA
* Adam has taken note of all your qualms/questions and intends to answer them all this Saturday
* Adam has gone to the trouble of inviting other ECU Manufacturers and Distributors to come and speak for a maximum of 30 mins each
* ECU Manufacturers and Distributors at their own discretion may be handing out "Specials" on the day, upon a purchase eg Wideband AFR Kits
* Merchandise and Promo Material will be on offer for attendees
* Mini-stalls will be set up from 1pm onwards if you wish to arrive early and talk to an expert
Many thanks go to JEM - Adam Neish - for stitching this together.
Pros (and Cons) without bias is the order of the day.
Remember, these presenters value SAU.NSW so highly that they wish to make our day memorable.
Win-Win !
  • Like 1
ADDENDA
Win-Win !
That is awesome Terry!
Really looking forward to this.
Hats off to Adam :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
