  • Replies 302
If its got a number its a freaking corner biatches. And it does. Its turn 1. :upurs:
I'm pretty sure it was Kel's camera (with Scott Speilburg's help) so evidence will no doubt be posted :rolleyes:
No... It's one change in direction.
hahaha now you've gone mad, turns 11 and 12 at EC are one line but 2 corners. Turn 8 at Wakefield is 1 corner with 2 distinct turns :rolleyes:
Just follow the numbers, you can't go wrong. They even write them on the marshal's posts for you
Well there's a tiny straight section between turn 11 and 12 at EC, not so at turn 8 at Wakefield :rofl:
I never said that you can't have two turns going in the same direction in a row, I just said that a double apex turn is one corner :D
But yeah, it's whatever the circuit manager deems it to be :rolleyes:
LOL - who's got time to look at marshal's posts????
hmm seems we have a draw :rofl:
so is it a kink or a turn? LOL
But............. since when is a kink NOT a turn? :confused: :rolleyes:
hope your not discouraged from coming again Jimbo...
I was going to come out with you but by the time I got out of the office you were already going....
plus a wet track can always be rather tricky
nah i actually had a ball the second time i went out although i was still rather shit, ha
everyone's gotta start somewhere i guess :)
yea we went out to get lunch at the paragon and then started off home, we were both hell tired from waking up at 5 uugh
thanks for the invite.
i'd love to give eastern creek a burl as its not such a mission to get to... with new tires might i add :D
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
