I got myself a pair of R33 GTR wheels for my GTST with 245/45/17 on them.
They're snow/winter tyres since they came from Japan.
I like the size since the tyre diameter is 2cm more than the standard 205/55/16
It looks good I find and gives good riding comfort.
(have a lot of potholes and speed bumps here)
In your experience is 245/45 a good choice for your cars or gives 255/40 more control?
http://www.tacomaworld.com/forum/tirecalc.php?tires=245-45r17-255-40r17
Edited by Torques
Size won't cause wobbley-ness, probably something wrong with balance or the tyre itself. I like the run the widest tyres possible, but since you have a GTS-t, I'd look at the guard to tyre clearance. Slightly taller sidewall would help with ride, so I'd stick with 245.
Difference between 245 and 255 isn't much, the tyre design/construction/compound would make a bigger difference.
Um. Wat?
20mm extra diameter is not a good thing. Hello speedo error. Hello taller gearing.
For all that.....there's nothing wrong with 245/45 as a tyre size in itself. It is neither going to be much better or much worse than a 255/40 in any real way. You'd be hard pressed to feel the difference in grip, firmness, sidewall flex, traction....anything. The 255 would be the better choice just for being closer to the right size (rolling diameter), that's all.
If you leave them on there 'til they wear out, and you want to go for wider tyres that still retain some of the extra sidewall height, you could probably squeeze a 265/40 onto 9" rims on that car. Gains you a bit extra rubber on the road and half the extra sidewall you have now.
Alright,
Thanks .. I was just thinking since 255 and 40 profile has smaller side-walls it would make a a real world difference
(just by using the link I provided in my first post)
I have the 245 on right now and clearance wise it seems ok
Um. Wat?
Hi!
Speedo error seems no too bad.
(that's compared to the standard GTSTs)
Look here:
http://www.tacomaworld.com/forum/tirecalc.php?tires=205-55r16-245-45r17
And 3% longer gearing seems to be an option,
Here's how it looks at the moment:
Edited by Torques
I run 265's on the back on 9" rim. I'd like to give a comparison to other size tyres but the last time i ran different size tyres they were 32 GTR tires, about 225 wide and rather old. Also car was stock and I ditched them about 4 months after buying the car
If you want to wait till you wear the current tyres out, fair enough. But go the 265's if you wont run into any problems with rubbing. I think mine are 265/35's but cant say 100% and too lazt to walk 4m to the car :)
Also, winter tyres won't be so good in summer eh.
Haha ..
Actually these tyres are very soft and traction is horrible if not scary!
Makes for a good show though ;)
That's why I need to change them but they're okay for getting an idea about sizes / clearance
(since the whole debate)
Edited by Torques
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
