  • Replies 52
well over 300rwkw, over 6 months and around 10,000kms - stock internals and I havent had any probs. I even had a boost spike to 1.9bar in 3rd gear on a hot summer day, hit red line pretty quick. I was a bit worried, but that was about 5 months ago.
I think it is important to decompress the stock RB25 if you are heading into this teritory - that's what the japs do, and what I did, good fuel supply and a good tune.
JMS R33 used a similar setup for well over 300rwkw, and Danny isnt exactly renouned for his mechanical sypathy.
If the engine is in good condition, you can push them pretty hard, but if it is tired, or been abused by a previous owner (who knows for sure?), you may run into trouble down the track. But generally, it is not an uncommon thing in Japan for RB25s to put out this sort of power on stock internals.
If you have the engine out, it would be well worth upgrading to RB26 crank/rod/pistons.
They are stronger and will drop the CR to 8.5:1 AFAIK, which is where mine is. An added benefit is an extra approx 100cc of capacity, not much, but it all helps:) Plenty of GTRs putting down 300rwkw with stock internals no probs - well, I havent heard of too many failures anyways - unless stupid things are being done (eg, thrashing a cold engine)
If you want to do a full rebuild, why not just drop a 3L bottom end in. In NZ guys have run mid 400rwkw without problems, and you have all that 3L torque, hmmmm:)
I did the GTR rods with my rebuild with Arias forged 1.0mm OS pistons. I got the full balance, bearings, O rings, lightened flywheel, x rays and crank cleaned out and straightened.
I have to say, it may just be the balance and the crank straightening which spun by hand easily when i torqued the crank in (and didn't before), but it felt soooo much smoother afterward. The extra mass of the rods probably limted the ebnefit of lightening the fly.
yer, im doing the same, drop the car off in 2-3 weeks. Just waiting for parts.
RB25 crank (they are fine)
RB26 rods
forgies (not sure what yet)
Reco'd head - no cams
with all the usual balancing/machining etc etc, with my GT30 it'll go quite nicely.
If you were to go the 3ltr, you'd need a GT35 to make the most of it...
yeah' date=' 25 block, 26 crank and rods, forgies, cams, thats me :cheers: QUOTE']
This post seems to contradict this one .........
I want RB25 cred
It is hardly an RB25 if it is stuffed with RB26 internals.:confused:
well, rb25 still stanped on the engine number is what i was referring to. I am building the motor to suit me, not anyone else, i cant compare with the sub zero boys producing big kws in there gtrs n supras so dunno if its going to stand out much.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
