I know there is a sensor that controls fuel on my rb26 according to temperature, does anyone know how I can test the one I have now, and where can I buy a new one.
I have a power fc and was also wondering if I can use that to see if the sensor is good or not.
Thanks.
https://www.sau.com.au/forums/topic/444541-looking-to-find-a-new-sensor/
Coolant temperature sensor. Do some googling for the expected resistance vs temperature. Test it in hot water on the stove with a thermometer (at one cold temperature and one hot temperature) and see if it lines up with the spec.
You can buy a new one from Nissan, eBay, about 30 trillion on-line retailers, etc.
Edited by GTSBoy
Don't RB26s run an air temp sensor to measure how hot the air going into the engine is? I would put that one ahead of the coolant sensor.
Pretty sure you will find that would actually have far less of an effect on the fuel ratio.
Edit.
Actually I'm not sure the ecu even uses it.
Edited by Ben C34
I pulled my plugs and seem like its running rich. And at one point it was hard to start. Once started it runs fine. Looking at idle my afr gauge was around 12s. I would have to go into my power fc and manually pull fuel out to get it to read around 14s or less. Im still waiting on some parts to reach then ill test and tune things. I have a strong feeling that my temp sensor is acting up.
The ECU uses it, but as far as I can tell, not for anything in the day to day setting of mixtures or timing. I think it is only there to call a halt to proceedings if temperatures get way too hot.
i think it uses it to pull ign timing when inlet temps get too high....i'll double check though.
Edited by Badgaz
looks like it'll do both, however it is inj vs airT and boost. which i'm guessing might only be enabled if you have the PFC boost control kit. 50 degree airt = 0 60 degree airt = 3 degrees retard 70 degree airt = 5 degrees retard
i think i have this same problem with my wifes GTR...the temp never went over 75 on a night of logging and tuning which meant it was always getting slightly more fuel across the whole map.
Doesn't really matter what the PFC does with it....it matters what the factory ECU does with it. Which isn't much.
Face it, about the only Nissan engines that have the air temp sensor are the RB26 and the SR20. And the sensor is a big lumpy slow reacting piece of crap better suited to measuring coolant, so it's hardly going to be used for serious business. That's why we have air flow meters.
  • Like 1
its much colder here in NZ. it was about 8 degrees that night. it matters to me what the PFC does to it....and i don't care what the Factory ECU does, but i'll find out anyway...and i think the OP has a PFC. Just checked my logs and water temp was sitting 75 degrees to 77 the whole time...the IAT was showing 30 degrees....
Badgaz, GTSBoy was referring to the air temp sensor, not the coolant temp.
It sounds like your wife's car might have a low temp thermostat installed. Which sucks. Alternatively you could look online and fine the resistance at various temps for the coolant temp sensor and test it with a meter. I would do that before pulling out the thermostat.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
