R32 GTR / RB26 sellout
RB26 R32 GTR Long motor. Come from a car with 52,000 on the clock. Compression was 160 across the board. Comes with intake but no hotside $3200
R32 GTR 100mm Trust tube and fin intercooler with HKS hard pipe kit $1300
R32 GTR Reo trimmed to suit above cooler $150
R32 GTR Excellent condition front bar trimmed to suit above cooler. Silver $600
RB26dett HKS 2530 twin turbos. Excellent condition. $1700
RB26dett Garrett GT2560r twin turbos. Excellent condition. $850
GTR Gearbox - Push Type from car with 52,000 on the clock $600
GTR Gearbox - Pull Type $600
RB26DETT PowerFc with Hand controller $700
RB26dett Nistune ECU $450
RB26/25/20 Nismo twin plate clutch. Probably 50% meat left $700
RB26dett GT35 highmount kit, 6 boost manifold, progate 48mm, braided lines, greddy y pipe intake $2200
R33 GTR wheels with random tyres with tread $950
R34 GTR wheels wth azenis st115 tyres $1400
R32 Uncracked dash pad. No Vents $250
R32 GTR Atessa Sensor $200
RB26 Blitz oil cooler kit suit GTR $550
Engine loom suit R32 GTR $140 each (2)
Z32 afms. Genuine. with plug. $200 each (2)
RB26 coilpacks - Yellowjackets $250
Old school Greddy Profec EBC. Complete. $175
All located in Campbelltown. Sydney
Pics over the weekend
https://www.sau.com.au/forums/topic/444664-big-r32-gtrrb26-parts-sellout/
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
