Hello
I have a r32 gts-t.
Ive read that the oil pump, or something like that, is weak on the RB20 det the same as it is on the RB26 dett. Is this true?
Also Ive read that the rb25 det and the rb26 dett have stock factory oil coolers built in. Is this true?
If I am uping my boost and tuning the car to go over 300hp, should I invest in a oil cooler?
https://www.sau.com.au/forums/topic/444694-rb20-det-and-oil-cooler-questions/
Even for a stock RB20 there sould have an oil cooler. The RB20 is one of the only turbo engine I know coming from factory without any oil cooler at all. :(
WTF nissan ?
I installed an oil filter bracket of a RB25 and the factory oil cooler of the CA which is bigger than the one of the RB25.
The oil heat up to 85°C pretty fast, and stays between 85 and 100°C as long as I don't go berserk. When I hit the gas pedal and the use the whole rev range the oil climb to 120°C in 10 mins or so on the road.
So even with a factory oil cooler bigger than the RB25 unit I still have my oil temp too high.
I bought a 16 row mocal oil cooler with a 92°C thermorstat. I should install it next week. I hope it will be sufficient to keep the oil within 120°C on track.
No factory oil cooler with a turbo is rare for what I know. As soon as it's a "performance" engine most of the time an oil cooler is installed.
On my daily driver I don't have an oil cooler but it's a N/A 2L motor with only 130 hp@ the fly stock. But the 2.3L N/A 160 hp engine have one.
Hello
I have a r32 gts-t.
....considering an aftermarket oil pump will cost more than a good condition rb20, just keep it off the limiter as much as you can and don't worry too much about it. Odds are something else will fail before t he oil pump in a factory 20.
Yeah, but they are coolant/oil heat exchangers.... not air/oil heat exchangers. As above, invest in a good oil cooler system... spend good money on the adapter block/thermostat and lines... if you need to save some money anywhere, buy a cheap core. They work almost as well, but when you trash an engine they need to be replaced (you can't clean them out like everything else) and they damage easily. I use greddy thermostat sandwich plate's, compact and work well.
If your worried about oil control, have a good read of the oil control thread.
....I have a soft spot for rb20's
J.
Hello
I have a r32 gts-t.
You'll have to do more than up your boost to hit 300hp. Why not just get an RB25 (preferably a Neo) and go from there?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
