I stand corrected, but was under the impression that this was controlled by jumper settings in the unit, rather than fundemental differences in the amp sections etc.
If it is the same as the V35 unit, it is just a jumper in the unit, the unit is otherwise the same, with the exception of a larger/fanned heatsink on the output stage IC, obviously due to the extra heat generated by driving speakers instead of just an amp input.
I am using a V35 'Bose' HU on my non-bose system, but I swapped the heatsink/fan from my old non-bose HU.
When I say 'jumper' they are actually a soldered surface mount resistor which needs to be moved, very hard to find if you don't know where to look. again that is for the V35 HU, not sure about the V36.
Ah, I see. That said though, my PCB had no trace leading to pin 1 which is meant to be the remote power output for the external amp.
Still, you have me curious all the same. If that means I can convert my HU to line level output, it might actually clean up the noise floor.
Nick, on the earlier units you are correct . These are a different matter. They are either amplified or not .
Thanks Chris,
Was waiting for the definative response on this...
So is it actually a better head unit, in terms of specs, or just optimised to drive the Bose amps and I assume low impedance speakers?
There does seem to be nothing on the facia stating the Bose bit, apart from the badging on the woofers and sub.
  • 5 weeks later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
