As the topic would suggest, I have a set of Xspurt/Bosch/EV14/id1000 injectors for sale.
The only difference between the above is who seems to sell them. They're all the same injectors. These ones are Xspurts, which are sold locally in AU, and are flow matched and such. (they're what scotty sells, exactly what he sells, because that's where I got them)
I used these for about 5000kms without issue. I only replaced them because I THOUGHT they ran out of flow, but it turns out it was a bad fuel filter. (really.)
I'm looking for $500 for the set of 6. I can negotiate within reason.
These are the 3/4, 14mm length style, so they'll fit in a variety of different cars. How to fit id1000's into XYZ will yield you info on whatever you want to put them in to!
Please send a PM on forums, I reply to these super quick.
I'm in VIC - Can deliver them if you want, otherwise can post them if you're happy to have them posted out.
Greg
https://www.sau.com.au/forums/topic/445440-xspurt-bosch-ev14-1000cc-injectors/
Bigger is always better with Injectors Mr Platts.
Why wouldn't you want 450FWKW in the Micra?
Why not use them on half duty cycle? How lovely that would be. Longevity and shit!
$400 now, plus postage if you aren't in VIC (I'll bring them to you if you are)
Note: These do not have plugs. Pm scotty nm35 for some (about $60).
No plugs because these can go into a variety of different engines, all of which require different plugs. ;)
^^ That is for adapter plugs. I can do crimp on plugs for half that.
If anyone wants these but are worried about them being used, I can flow test them for a minimal charge. Removed due to upgrade by myself. ;)
  • 1 month later...
Hi mate are these still for sale? What were you running them in? Im pretty interested in them for my R34 gtt.
No, I converted them for RB26 use and Greg sold them. I can help with new ones if you need a set. ;)
He was running them in his Neo, 34 4 door.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
