As the topic would suggest, I have a set of Xspurt/Bosch/EV14/id1000 injectors for sale.
The only difference between the above is who seems to sell them. They're all the same injectors. These ones are Xspurts, which are sold locally in AU, and are flow matched and such. (they're what scotty sells, exactly what he sells, because that's where I got them)
I used these for about 5000kms without issue. I only replaced them because I THOUGHT they ran out of flow, but it turns out it was a bad fuel filter. (really.)
I'm looking for $500 for the set of 6. I can negotiate within reason.
These are the 3/4, 14mm length style, so they'll fit in a variety of different cars. How to fit id1000's into XYZ will yield you info on whatever you want to put them in to!
Please send a PM on forums, I reply to these super quick.
I'm in VIC - Can deliver them if you want, otherwise can post them if you're happy to have them posted out.
Greg
https://www.sau.com.au/forums/topic/445440-xspurt-bosch-ev14-1000cc-injectors/
Bigger is always better with Injectors Mr Platts.
Why wouldn't you want 450FWKW in the Micra?
Why not use them on half duty cycle? How lovely that would be. Longevity and shit!
$400 now, plus postage if you aren't in VIC (I'll bring them to you if you are)
Note: These do not have plugs. Pm scotty nm35 for some (about $60).
No plugs because these can go into a variety of different engines, all of which require different plugs. ;)
^^ That is for adapter plugs. I can do crimp on plugs for half that.
If anyone wants these but are worried about them being used, I can flow test them for a minimal charge. Removed due to upgrade by myself. ;)
  • 1 month later...
Hi mate are these still for sale? What were you running them in? Im pretty interested in them for my R34 gtt.
No, I converted them for RB26 use and Greg sold them. I can help with new ones if you need a set. ;)
He was running them in his Neo, 34 4 door.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
