R33 gtr rb26 engine, head has been serviced new headgasket, arp studs, new valve stem seals, n1 oil pump, tomei oil restrictor, near new water pump and many more things.
Comes with r33 gtr turbos etc
Intake manifold + throttle bodies
Comp tested 160 1,2,3,4 157 5,6
-4000
Garrett 2860r -7 turbos great condition fully rebuilt 2500kms ago -1300
R32/33 nistune ecu, has tune just for exhaust intake and boost increase -450
R32 gtr seats pretty good condition -550
R32 gtr diff -500
R32 gtr rear wing -100
R32 front and rear strut braces -150
R32 gtr tailshaft -100
R32 gtr exhaust 3.5 to 5 inch tip
r32/33 gtr after market downpipe -100
r32 apexi duel bovs -100
r32 gtr intercooler and piping -200
Rb26 r33 gtr gearbox, no noises or crunches perfect working order -900
Rb26 camtech cams used for start up only! Unknown spec but good for power, can drop in with stock valve springs -300
Rb26 apexi air intake + filters -100
Will upload pics on request
message me or text me on 0481360765 for more info
Edited by nickgtr32
https://www.sau.com.au/forums/topic/445502-rb26-engine-and-r32-gtrrb26-parts/
Rear sway bar sold
Also have full r32 gtr brake set up for sale
4 piston fronts
2 piston rear
New seals
New discs and new genuine brembo race pads. Sprayed in black.
-$650
N1 oil pump suit rb26 -$150
R32 gtr fibreglass headlight intake -$50
R32/r33 gtr engine mounts near new -$75
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
