Hey guys
Since some weeks I got this metallic sound from the rear of my car. At first it only appeared on the left, meanwhile on both sides.
It appears when I start moving the car, forward and reverse. Also when changing into 2nd and start accelerating.
It does NOT appear in every gear or always at the same "time". It sounds like 2 screwdrivers hit against each other.
Also you can not "make" that sound with "shaking" the car for example, so theres nothing haning around, nothing lose or not in place
and so on. A friend of mine is mechanic but we could only check without a lft but he couldnt find anything. Not the wheels, nor the suspension, not the exhaust, not the shieldings bla bla bla
I srsly got no clue what to do, and since a week, this guy has the same problem. Actually it´s not a real problem, at least so far. But everytime I stop and keep moving again, there´s that annoying sound and ofc that´s not how the car should be so I rly wanna fix that.
Sry for bad english, and sry for not being able to explain it better ^^
Here are two short vids, in which you can hear that sound. Sry for bad quality, cellphone sucks :) When you hear it, you´ll straight know what I am talking about.
Thanks a lot
http://www.dailymotion.com/video/k6mFvU0Vq7W3yw8kBlr
http://www.dailymotion.com/video/k1Am8JdGgI3N9O8flgQ
https://www.sau.com.au/forums/topic/445531-33-gtst-s2-metallic-noise/
I jacked the car up and tried to shake and turn the wheels in every possible direction. Should I hear it then too? Cause there was nothing. But I´ll have a look again.
if there play in the wheel when u tried? u might not hear it unless the wheel is under load being driven
Nah I´d say nothing. I turned and shook em in every possible way. Like said before, if you would hear it while checking, you´d also hear it while the whole is getting kinda rumbled by driving over a curb for example, I guess. But that doesn´t happen
Somebody meant while driving by might be something to do with the "struts" ( if I got the correct Translation ). I can´t see how this could be oO If, it would be more centre of the car, not obviously down and rear, correct?
A stainless exhaust can make a similar noise when tapped, on take off the exhaust will tend to move/vibrate more
also if there was some loose fragments of broken cat converter, they could be tapping inside the pipes.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
