Just starting to do a few track days.  My track has 3 long straights followed by hairpins so i dont' wanna be diff locking all time.
With the heel and toe technique -  Ive got a r33 gts-t with evo brembo front and rear.  The brakes are so good, it only takes a light touch at the top to get it to stop.  My accelerator pedal is much lower down than the brake so im having big problems with heel and toe to downchange gears (im not even getting it close)
I was going to put a layer or two on the accelerator pedal to try and the get the same sort of height, but even with this the brakes are heaps sensitive.
Any suggestions ?
thanks
  • Like 1
  • 3 years later...
Tried some new plugs as old ones were fouling just moving the car out of the garage ....
NGK   BC PR from factory come 0.9 gap, need to get them to 0.7 with a gap tool.
ngk 1269     bcpr6e
can just bend on the outside
  • Like 1
With new oil cooler it takes 20-30 minutes of idling to get the gauge to move.  Even at the track it takes a while and is always super low temps.  I installed it low and air flow, ive now had to put cardboard across the front to try and keep some heat in - just gets so cool so quickly.
15-60 for race oil and tracking is not necessary now, just regular 15-40 Nulon is fine.  Even with the oil cooler 4.75 L of oil is needed to fill up.
Edited by R377
  • Like 2
I had similar with my 25row cooler, to the point where I was kinda concerned about the oil never getting hot enough... ever. It was perpetually under 100C _without_ the cooler and most of the RB life driving around was like 65C...
Mine is now behind an indicator which is nice enough to remove/add for the track (in a R34). but yeah, it overcooling is something that happens on the road..
  • Like 1
thanks for the read and reply, something you don't realise till after you have installed it !
  • Like 1
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
