hey, ive currently got a rb20 32 with the following mods: front mount, 3" catback, pod filter, boost controller running 12psi on an rb25 turbo. im wanting to upgrade in the near future chasing 210kw+ while retaining good response with the following setup; hks 2530 or garrett gt2860, nistune, 440cc injectors, as for supporting mods thinking fuel pump, alloy radiator and hd clutch. am i missing anything/any extra suggestions?
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/
Bigger injectors and turbo will require an aftermarket ECU and some dyno time for the security of not blowing everything to bits.
I personally would look at a Haltech or similar also you'll need things like quality fittings on the fuel system and bigger fuel rail ect.
Also a bigger throttle body and a halfway decent intake plenum help.
Oil coolers are a must too since you live in aus.
I know its money but over engineering things for slightly higher than your aiming is never a bad thing.
Also a quality boost controller with individual boost profiles is good too.
I use a Greddy pro comp2 and have a low and high setting for regular driving/ rain and going fast.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342641
never thought about oil coolers, i was going to get parts that directly replace the oem parts so i dont have to fiddle around getting everything fitted up. its my first turbo car so i dont know much about modding but what exactly does a bigger throttle body and intake plenum do?
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342648
There is no need, not now, not ever, to change the throttle body or the plenum on an RB20 even if you're chasing 50% more power than your target.
Your Nistune idea is fine - it will do the job perfectly.
An oil cooler is a good idea. Buy a quality kit brand new if you're going to do it. Not some cheapy linglong brand or secondhand.
Don't buy 440cc injectors. That number implies that you're thinking about GTR injectors. Waste of time and money. Just buy brand new Bosch EV14s of >700cc rating and be done with it. They will work fine even at your lower initial power level target and will also allow you to make more and/ore go to E85 if you feel the need. They will also be brand new, not busted arse 2nd hand shit.
Consider one of the Hypergear turbos instead of the ones you listed. A simple highflow of the RB20 turbo will more than adequately give what you're wanting, or he has a couple of brand new options also. Much much better value for money. Also not busted arse second hand shite.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342656
Well I personally run a Greddy throttle body and a slightly larger intake on my RB20.
I did it for insurance as I run a Precision turbo PT5558.
I will however admit that I had professional assistance building my engine.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342661
i was actually going to go for deatscwerks new injectors, they also have 550, 650, 800, 900 and 1200cc, my current injectors have played up on me already so i wasnt going to run the risk of getting 2nd hand, as for the turbo is there anything specific you know of that would work? i hit full boost with my current rb25 turbo at 3000rpm, i dont want anything laggier and quicker spool up would be better, dont mind forking out a bit extra for the turbo if its something good hence why i was thinking on one of the above (new)
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342666
I have similar mods but also a walbro 225 fuel pump wired in at 13.5 volts this increases fuel capacity slightly so I can run higher boost without leaning out on the standard injectors.i also have a mines ecu and I only run on premium 98..car goes very well and revs nicely to 8000.at the moment with my 3 degrees negative camber it wheel spins on boost in first and second gear.getting rid of the camber soon.they say ceramic turbo never boost past 13.5 but I been running 15 with no problems.maybe if you drifting may be another story also get a good afr wideband fuel mixture gauge.real important to monitor mixtures.on 15 psi I am running on full boost 11.1 which is safe.this tell me that my injectors are suppling enough fuel and im not running lean.apparently they say mines computers are shit,but I have not had a drama at all and ive had the car for 2 years as a daily.
I am in the process of installing the following mods..kinugawa td05 18g 8cm exhaust housing,nistune ecu,700cc injectors,z32 afm,,new recoed head,and tossing up whether to instal hks 264 9mm lift cam shafts....I don't drift it so I think this will be more than enough for the street.the rb20 is a awesome motor.i nearly bought a 32 gtr but I think as a daily the gtst is a better car.
you get dickheads on the forums just ignore them..they are like bored housewives.alot of the rb20 stuff links don't work.and there are a lot of awesome people with good advice...good luck
  • Like 1
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342668
i dont think ill push the current turbo past whats recommended (14psi max i think) because its my daily and i dont have a huge budget, would rather play it safe, i guess i'll do a bit more research on turbos, see if theres any other alternatives, i plan on getting gtr after im done having my fun with this car haha, nothing against the gtst and rb20's i love my car but i think a gtr would just have that bit of extra presence on the road
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342674
It isn't high boost that kills ceramic turbos. It's high shaft speed. Shaft speed is a function of flow (and boost, but never mind that for the moment). An RB25 turbo flows more than an RB20 turbo and so will make more boost at lower shaft speed when put on an RB20. Ergo, you CAN actually run at higher than "sensible" boost levels at the same level of risk as running "sensible" boost levels with the 20 turbo.
But there is still risk. These things can and do die at stock boost.
Go have a look at the Hypergear site. The RB20 offerings are clearly findable.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342795
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
