Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Gareth, you have put 300k KMs on your 25, what are you doing laps of Australia or do you live in your car cause dam !!!!
I've owned my car since 2002. when i bought it it had 134,000kms on it. i've still never lifted the head off the motor and i've done all the maintainence myself....most of the problems are with the ancillary parts of the motor failing over time e.g turbo....
If you keep standard internals its well within the realm of possibility.
So you are saying it is possible with a blown 25 to build a 25/30 on the road for that price? Don't think so. Not even close.
My bet is that your highly strung 4G63 will grenade long before my 25 will! Crankwalk anyone? :woot:.. Mick O
Edited by rondofj
Lol care to place money on that Ronaldo? Dunno how its more highly strung? Im running a pound or 2 more boost than your car on Ethanol with a lower comp ratio and probably make similar to a little more power than you.
Its just a better designed more efficient engine than the old RB :)
agreed, RBs are old dinosaur tech
Where did they over engineer it?
Certainly not the oiling system....or the cooling system....or the cylinder head....or the turbo chargers......did I mention the oiling?
Stock engines weren't designed to rev at 8500 rpm for 10 secs bouncing off the limiter at double the intended boost. Do that to most engines and you will kill them.
Edited by XGTRX
Micko Atleast knows where his timing is sitting... Just saying.
  • Like 2
Yes, and I know this because I have done it. Thanks champ.
Same here. Stock bottom end untouched. All up less than 700 including oil etc for everything including retune. Took a whole week working on it a bit after work.
Not what I would call built though, as it's untouched.
But.... I know what I'm doing.... can set timing etc :)
Can't really see the point building one when a 200 buck engine does aso well!
Edited by Ben C34
  • Like 1
Sorry my bad. I assumed that going a 3L you would upgrade the supporting mods, water and oil pump, timing belt, clutch and at least a dyno tune. Obviously not the case, I apologise.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
