Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
And I could safely say nobody KNOWS if thats my problem, they think it is. Having tried so many things and even making the bov atmo, I am pretty sure it isn't entirely my problem.
Look at it this way, if I shift under load (and give it 3-4secs before I bring the clutch out the problem wont happen at all. Why? If I drive with NO boost under 2500 and shift going up a hill at 40-50, the problem always occurs. Why? How can there be bov reversion in boost-less conditions?
The problem isn't from the bov
It's reversion/surge from the turbo as it's a much larger turbo than std
It only needs to flow alil air back on the afm and it's will effect it
Compared to a std turbo and and ribbed std rubber intake
Why bother starting this thread and asking for people's suggestions when clearly you ain't going to listen to them and try it out
Best to just take it to a tuner/good mechanic to sort it out
  • Like 1
Also did you even fix the exhaust restriction you had posted earlier and get the tune touched up
As you said they had to retard the timing a fair bit
Plus I seen in your engine bay pics are you still running one of those blitz metal type pod filters ?
As when I got my car tuned 2 months ago I was speaking to mark at Unigroup and he was telling me those metal mesh type pod filters are rubbish
He had a sr20 Datto there that was making 270kw last tuned but barely made 230kw
Changed the air filter and bang back up to 270kw nothing else touched
They may look like they flow well being ss mesh but he said they are crap
Who would think a filter would make 40kw difference
Yes exhaust restriction was fixed long ago and tune touched up too. Mark removed my filter to see if it would make extra power but it didnt, but if it really is known to be rubbish then its goin to the bin soon
Yeah same thing with the Datto but was good prior the check up when first tuned but after it was clogged bad
Shit design and filtration and clog easily
Even the cheap 3a racing or saas ones at autobahn flow good
Seriously dude buy a new MX-5, drive it, love it, pick-up babes in it! Leave the Liners, Subies and Evos well the fcuk alone.
You seem to have nothing but problems with every nissan you own, some things are are just not meant to be...
  • 3 weeks later...
Thread revive- just had an afr log done on the dyno as suggested here- seems to be ok, yet still gets me 20-21L/100kms on short metro daily drives (only) 4kms each way with 1,2 or 3 2nd and 3rd gear hard pulls on the way. On a mix of motorway and metro driving, I got 16.6L/100kms last week. Dont know why it made such crappy power this time either, the only thing changed is a new O2 sensor and Gizzmo IBC-R ebc on same boost and gain set to 16.
Afr seems alright on cruise and also WOT maybe even a touch lean, no smoke out the exhaust, maybe injectors are leaking.. Tuner verified afm is ok with the voltages its reading. Said to change Blitz pod filter as they known to be shit. Mighta get an Apexi soon
Or maybe it shat something whilst you have flogging the f**k out it when there are issues.
Also your 4billion psi boost spike probably killed a few ring lands as well.
Or all your f**king about with it has thrown the tune way out.
  • Like 1
Told you those blitz metal pods are rubbish
That could be your lost power
when did you change your o2 sensor
As you said you got 16l to 100km last week from 20l to 100km it usually is and 15-16l to 100km is on par with a highly modified 6cylinder turbo
Also highly unlikely to be a leaky injector internally as afr are good and you would have other symptoms
Hard starting after left for a while and smoke on first start up from flooding
If it had a external fuel leak you should be able to smell it
Somebody put that zebra back in the zoo lol. O2 was changed a couple months ago, and only managed 16.6L/100kms through a couple of longer motorway drives. Mark said my economy is on the high end and that normally a modified car would average 17L/100kms on metro drives and 14-15 on longer cruises. He told me stock 1jzs average about 16L/100kms with stock injectors, thats a bit much wtf
Edited by rondofj
That's a lot of fuel, pretty sure I was using less than 15L/100km when on E85, on 98 it was 12, same as stock with a mix of driving.
Wtf is this guy dumb
I'm not going to bother posting after this
What a waste of time
Even what a tuner tells him goes in one ear and out the other
He just said he got 16.6l 100km last week and tuner tells him 17l 100km is normal for a modified car and his still complaining about the fuel economy
yet his air filter is blocked which will make fuel consumption worse and it's still on there
He should should sell up and buy a Toyota Prius or yaris
  • Like 1
How do you know my air filters blocked, assume much? Your the sort of guy who believes changing the air filter resulted in a 40kw gain from a 230kw datto to 270kw wow haha..
And niether did you understand my post. Tuner said 17L/100kms is average for metro driving, I'm doing 21 or even 20, does that seem close to 17? Mixed cruise driving he said 14, I did 16.7-17 which is still a bit from 14.
Ok I will be nice to you and get a new filter, might surely get 40kw since you swear your mate did ;-
Ron, I'm just going to say this.
My car when running had perfect AFR's, and I mean wideband, wideband controllers, everything. I'm talking it'd sit between 14.5 to 15.1 AFR the entire time, on cruise, all day, every day. Cold starts were lovely. It'd be a nice curve from 14.7 to 13.0 on boost and 11.9 on full throttle. It was lovely.
My fuel economy wasn't much better than yours. I'm talking 250L from a tank on E85 (55liter fill up). Better on 98, but still very much in the ballpark of what you're experiencing.
If your AFR's are fine on the dyno, then it's done. Your fuel is what it is. That's it. There is nothing to be fixed there, unless you want to play with a wideband and see the cell that is 20% throttle and 3PSI of boost is actually got an AFR of 9.0 or something in it.
If it doesn't, then that's it. That's your economy. You find this out in about thirty seconds upon having a wideband, btw.
I never said it was my mate that gained from a air filter
It was mark from Unigroup who told me about it and it was tested right on the dyno
Why would he bother lying about it
You were being a tight ass before and wouldn't get a wideband or get a power run
But get a new ebc and can't spare $20-30 for a new pod filter
You surely are a stubborn ass
You know best even better than qualified tuners and mechanics
keep playing with your car and fixing problems that don't exist
Edited by hy_rpm
What do you know about me n my car...your just probably another adolescent or 20s something keyboard clown on the internet trying to hammer his point across haha. I dont think Mark would tell you something like that, hes a top bloke who would know that you dont just gain 40kw from changing a rubbish air filter.. .
This thread surely delivers..
Edited by rondofj
You can ask mark your self
I'm not a backyard wannabe mechanic like you
I'm a qualified mechanic/technician
For 3 years now and have seen a few customers that seem to know more than us when work on cars everyday for a living
Which you sound like one of them
If your filter is shit and dirty it can easy cause 40kw loss, depending on how shit and how dirty, I haven't seen your filter so can't say if it's your issue or even part of you issue, but the filter is the only path the air has into the engine if the air can't get in it will loose power simple
I am a backyard mechanic and you know why, because in the 20 years I have been working on cars I have learnt a thing or three and one of the things I have learnt is that just because you do it for a living doesn't automaticly mean you know anything, I have seen plenty of "real mechanics" that are just dumbarse farkers with no clue, even more so when it comes to so called tuners
Same goes for what I do for a living, I know dudes that have been doing twice as long as me that are just useless, so don't be fooled into thinking just cause someone does something for a living that automaticly they have a clue
  • Like 2
