I'm not aware of another day in our calendar, so presuming will be entering the WRX day 16th Aug?
The site shows 95 spaces, but just received an email stating 20 spots left - not sure what is going on there either?
http://www.wrx.com.au/event-899288
https://www.sau.com.au/forums/topic/446275-august-sandown/
:thumbsup:
BTW For those new to this year's season, probably a good idea to review the SAU classes - first page of http://www.skylinesaustralia.com/forums/topic/437292-2014-sau-vic-motorsport-championship/
and advise emts & miniwog of your expected class.
Also on the day, there tends to be an SAU hang out, look out for the SAU flags, motorsport shirts etc and pop in to say hi.
https://www.sau.com.au/forums/topic/446275-august-sandown/#findComment-7355900
Yeah send the info this way and I'll get the updated spreadsheet out a day or so later.
f**k me when did the prices skyrocket...thats more than PI...
WRX round at Sandown in March was $205. Their one around same time last year was $195 but SAU round was with AROCA last August and that was $210/230/250 depending on the date you entered.
The real issue is when they go for the cash grab like they did in March and again at Winton with PCV and over subscribe the day. I'd rather spend another $20 and get a decent run rather than save it and get f**k all laps.
https://www.sau.com.au/forums/topic/446275-august-sandown/#findComment-7355962
Seems to be quite a few 200sx's joining track days in Vic... Great stuff. I'll be coming back to the track next year, looking forward to mixing it up with you guys :)
Start the diet now, so you can fit in the seat :yes:
  • Like 1
https://www.sau.com.au/forums/topic/446275-august-sandown/#findComment-7356096
Re prices: seems $215 for non members, $185 WRX members and $275 is for their race series
Though I tried to check the number of entries and the link doesn't seem to be open now, full?
Richo, not sure I'm going to enter next year if you require entrants to be dead :-)
https://www.sau.com.au/forums/topic/446275-august-sandown/#findComment-7356116
I'm trying to enter but (after logging in with my wrx username/password) it looks locked down?
Access denied (error 403)
Sorry, but you have been denied access to the requested page or resource."
https://www.sau.com.au/forums/topic/446275-august-sandown/#findComment-7356691
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
