Hi All.
I'm looking at a BNR32 and the VIN/build plate has been removed by the importer. He reinstalled it but lost one of the little rivet-like things and has ordered a new one from Nissan.
He says he removed it because when he degreases the engine bays the degreaser strips the blue paint/coating from the VIN plate.
Does anyone see any truth in this?
I painted my engine bay and removed the plates.
When it came time I used metal rivets instead of the plastic ones - so hope don't get in strife or loose a sale if I ever sell.
I have seen the blue flake a little off the plate so I'll double check mine in the morning.
I wouldn't expect degreaser would remove it but something like carby cleaner and a rub now that I can see causing damage to the plate.
I think some heavy duty degreaser with some kind of hot wash was used on mine that resulted in the blue from the bottom of my factory VIN number being damaged. I've seen this once in a while in engine bay shots when ppl sell cars.
First you have to explore this products on some online store. you will find huge varieties of this products. This will help you to take decision to buy new product.
Thanks.
Thanks for the spam advice.
Thanks.
so, Maccas > kfc?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
