Hey guys so I have one of these that i have just fitted up with the new donk and I'm just wanting to know what everyone that has one thinks about the release point on it?!
I find myself constantly slipping the clutch to much because the bloody release point is just about at the end of the stroke! I hate it its nice and light dosnt shudder but which is mad for a clutch that apparently can handle a lot of power but that very very late release point is crap.
Anyone else experience this or is it just me and some how I have buggered up somewhere? OR is there a way someone has discovered to correct it?
cheers
ben
Is the clutch rod (between the pedal & the master cylinder) adjustable in your car - I know it is in an R33 GTST but no idea on an R32. If it is, adjust the length to set the takeup point where you want it - shorten the rod will make it grip at a lower pedal position.
Yeh i could do but then the pedal will sit lower and dosnt really fix the concern. The only time I have driven clutches that feel like this are ones on the way out? Strange on the gismo site they do say that they have designed it to only have 15% of the original stroke..
I was more worried I had buggered something up but if that's how they are then it's all G I guess! Thanks for that bud!
If I put a bigger slave on it it would increase the stroke required and make the pedal even lighter win win might have to look into that now then
I could be wrong but don't they recommend not using a Nismo slave cylinder with the Coppermix? Again only recalling stuff I thought I read in the past!
This is true, but I call bullshit. Mine has been working fine for the last 9 years with the Nismo slave. No idea why they say this.
Definitely going to run one of those nismo slaves! The only reason you wouldn't run a bigger slave is if your running out of pedal travel and the clutch doesn't disengage properly with the extra stroke required but it is disengaged with something silly like 4mm of travel so no probs with that!?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
