As you may know I have the "Gurgles" in the RS4. Probably due to the way the Skylines members instructions said to install the FFP.
Came across info on a "Swirl Pot and Header Tank" Has anyone used one, or knows anything about it?
Edited by 66yostagea
https://www.sau.com.au/forums/topic/446753-swirl-pots/
Obviously, the swirl pot must be mounted above the head height of the rest of the cooling system to work properly, but the theory is; the coolant draws through the system using convection.
The leg connected to the bottom rad hose draws coolant in and down as it is colder, and this allows a constant inflow from the hot side of the cooling system.
Any bubbles throughout the system will obviously migrate to the highest point over time, and this can then be purged completely and will the draw coolant with no air from the overflow tank; thus eliminating any air pockets within the system.
Convection is a surprisingly effective way to move hot liquids; early cooling systems that didn't have a water pump used convection to provide fluid flow through the system.
As time went by more effective means of cooling were required as more power (thermal energy) was generated and space constraints for radiators and water volume were reduced.
You see many high powered engines (especially RB's) using swirl pots as they generate enough localised heat to flash boil pockets of water within the head; this then causes cavitation if it isn't released.
An inline swirl chamber is far more effective as it separates the bubbles directly out of the coolant flow from the engine, as opposed to just the bleed points. Obviously this system would still require the use of a header or swirl tank above the level of the head height of the cooling system.
Hope this clears things up.
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7364465
I am getting to the point where, after I finish the Dayz rebuild, I will take off the FFP and put the piping back to stock. It is pointless having an RS4 that has to tippy toe around.
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7364619
I realise its hard to photograph the underside of the ffp but if you can put up some pics I will compare it to mine (do you have a Greddy copy?) as I am not having any such problems.
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7364894
Seems like alot of stuffing around for what is essentially an unrequired mod (ffp)
Losing torque, and impacting negatively on the cooling system just to get some tidier pipework.
I said it before, it was a Christmas present from my son. It came with an Xforce cat
  • Like 1
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7376859
  • 3 weeks later...
https://www.sau.com.au/forums/topic/446753-swirl-pots/#findComment-7388808
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
