Hi guys,
I was putting my tyres back on last night and was shocked to notice pretty severe cracks/cuts on one of them - only to find more damaged tyres soon after. Two of the tyres have deep cracks (front right and rear left) and one has less severe ones (rear right). See photos below.
These are good quality tyres, Goodyear F1 Asymmetric 2 in 235/45R17, manufactured in late 2011. I bought and installed them new in Jan 2013, and they have only about 15,000 kms on them.
I'm running BC BR coilovers and stock 17" R34 GTT wheels with 20mm spacers. I've checked all clearances several times and can't see where it could rub, certainly not on the inside. If only the fronts or the rears were affected it would make more sense, but that's not the case either.
What could be causing this? Do these look like a bad batch/compound or more like mechanical tears?
Thanks heaps.
Front right:
Rear left:
Rear right:
This might be why Tirerack.com were getting rid of them for $100 each earlier this year. I have a set of same from the same 2011 batch on my car at the moment. I haven't noticed any sidewall cracks like that, but after 7000km they are nearly stuffed, and they are not a very good tyre anyway, so I will declare them well rid of when I replace them soon.
  • Like 1
The way most of the cuts appear suggests that its a tyre problem. If they were old tyres that had been sitting in the sun it would make more sense but could just be a bad batch as suggested
It doesnt really suggest a rub on something. I had tyres rubbing on a bit of the chassis that was pressed together and had a small section of flat steel sticking out. The fronts were just touching enough to wear out where the sidewall and tread met. Ended up costing me a set of otherwise great tyres. So I know what it should look like if it was rubbing. Because yours dont show a leading or trailing edge of a rub and they are just cuts then it looks like tyre defect to me. Or someone without much skill has tried to slash your tyres?
Talk to Taleb Tyres on here about it, they might have an idea and can sort out some new rubber for you if you dont have a trusted tyre shop you usually use. I got my Yokohamas for the rear from them and they have been great so far. My old Kumho KU31's were from there as well, also really good street tyres for the price
  • Like 1
Thanks heaps guys!
I have contacted the original shop, let's see what they say.
It's a real shame, I like these tyres, they're a good all-rounder with decent grip in dry and wet, and low wear...
Oh well more money into the pit :/
Seriously - gutters, on the inner sidewall? Only if you park on the footpath, with the outer wheel in the gutter.
Seriously - driveway? Ramp gutter/driveway? Drain pipes that poke out from said things....
Edited for, Mini roundabouts that you drive over, speed bumps, drains next to gutters, wooden bridges, section bridges, glass, nails, screws, car parts, children.
But they were made in 2011, so would be deteriorating and they need replacing regardless. The first time i spoke to my tyre guy, he told me never to use tyres that are over 3yrs old.
Edited by Stagea97
Edited for, Mini roundabouts that you drive over, speed bumps, drains next to gutters, glass, nails, screws, car parts, children.
To be fair, none of those things should ever be driven over in a Skyline. Mazda 3, yes. Astra, yes. Any other FWD nugget shopping/kid carrier, yes. Skylines should go around.
I'm pretty sure that the cracks on these tyres are not from mechanical contact with anything. I try to avoid parking on the footpath with the outer tyres in the gutter ;)
I've been in touch with the tyre shop and they reckon one possibility is running too low pressures. Which would suck, since I've been following the tyre placard info to a tee at all times (32 psi).
See how we go.
  • 4 weeks later...
Just to close this one off, I have replaced these tyres with a new set of exactly the same brand and size.
I sent the previous set back for inspection and they had several people look at them, it was deemed premature sidewall failure due to too low pressure.
I just wish that someone had told me what PSI to run them at when I bought the set but oh well, live and learn. A nice thousand dollar mistake.
For reference the recommendation is 38-40 PSI for these tyres - my Jap and Aus tyre placards both say 32 PSI for the exact same size tyre...
I wouldnt have thought 32psi would cause any damage at all, and should definitely be fine if you're running the factory diameter rims. I'm skeptical. Where does the 38-40 psi recommendation come from? Is there anything written on the sidewalls WRT pressure? What did the shop that fitted them pump them up to?
Well the official line is that low pressure combined with non-stock camber is the cause. These tyres were ordered online from Sydney and put on by a separate shop in Melbourne (probably originally inflated to >32psi), and I maintained the pressure at 32psi since.
There is nothing on the sidewall to indicate minimum recommended pressure, only maximum. I raised this with the seller also to no avail.
Yuh, they shouldn't suffer at 32 psi in any way shape or form except that the handling won't be as good.
Interesting. So my warranty claim was denied due to the 'low pressure' and 'non-standard camber', I wonder if I could refer this issue to anybody else? Manufacturer? I obviously don't have the damaged tyres anymore so it's getting a bit complicated..
Walk away. File it in the lessons learned basket.
Also, when I said that they "won't suffer" it is actually possible that they might wear out a little faster, particularly near the edges, if the pressure is a little low. 32 is probably not low enough for that to occur.
32 is definitely not high enough for sustained high speed driving though. The tyres will get hotter and wear out faster that way for sure. Difference might not be great, but it will be there. And it won't feel as good anyway - so best avoided.
  • Like 1
You could;
- Get a written statement from a recognised expert (i guess that means a mechanic?) saying that the tyres were not "fit for purpose" (assuming that is the case)
- Ring Fair Trading, or whatever the equivalent department is called in your state, for advice on how to proceed to get a refund.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
