Hey guys
I'm soon to get installed the following mods
gtss turbos,
tomei dumps,
Hks front pipe,
kakimoto 3.5" exhaust and
either 3.5" straight pipe or 100cell cat
I have a viper ecu, elec boost controller and handling mods
I'm hoping fir 320-330 awkw on this, fir fuel set up I'm getting sard 700cc and planning on a Walbro 255l pump
Is this all I'll need fuel wise to support my power goal or do I need to get a fuel pressure regulator and fuel rail too??
Any other thoughts on what I'll need to hit my goal?
https://www.sau.com.au/forums/topic/447046-fuel-requirements-rb26/
For a few bucks more you may as well get the Walbro 465L pump which is ethanol friendly in case you want more than 500hp and decide to get E85 some time. Directly wire it and you won't need to revisit your fuel pump for a long time.
  • Like 1
I was contemplating a 460 unit, I just thought it would be excessive. I'm thinking about e85 next year but thought the 460 would sound like a lawn mower starting up.
For $185 they are hard to beat, and the new turbine design is nearly silent. ;)
Bro. Pretty sure they are doing a he'll of a job while still pumping power through the motor that is just as old but probably will hold 300kw longer than the life expectancy of a ford
My XR6 Turbo had 325rwkw and 400,000 kms on the clock...
Well having just lodged my tax return im getting a lazy few thousand back... soooooo im thinking about getting poncams while i get everything else done.. given ive got the turbos fuel and exhaust im thinking it should be worth it..
now i've heard mixed thoughts about whether to go R, A or B, im thinking i might aswell go B cause the GT SS will be responsive as hell, i dont mind an angry lumpy idle and also if im going E85 down the track will help the top end figure?
thoughts?1
If you're gonna go cams. Stock, type R or mines shore pro 2. Tomei type b's, too much duration for lift given.
Pm XKALABA. He has done a back to back between the 260 and 250 poncam. Sometimes, bigger isn't better.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
