Hey guys, i am posting some items for a friend who has a ton of GTR parts to sell. If you see anything of interest and want more information just shoot me a message. Awaiting pics from him, will upload them as soon as i have them.
Willing to post: Items can be posted at buyers expense
Trust td06 20g turbo set up rb26, turbos rebuild 50mm trust gate $4500
R34 power FC dejetro used complete hand controller maps etc $1100
New power FC dejetro r32 r33 Gtr complete controller maps $1400
R32 R33 Gtr autronic SM4 plug in ecu
Special order no longer available plugs directly into oem engine harness $2800
Bnr34 OS giken twin plate with push pull conversion kit used $1700
Nismo pull type slave cylinder new$190
Hks afm replacement pipe alloy 80mm x2
2x Hks air filters new $220
2x billet hks style bell mouth turbo inlet $200 ea
Blitz Gtr air pod kit $225
Greddy oil cooler thermostat discontinued
New $240
Greddy oil cooler and remote filter rb $700
Oil cooler kit earls core rb $550
R33/34 ADR approved braided brake lines new $540
Defi boost gauge $150
Top secret igniter holder rb new $70
Trust clear timing cover rb26 $75
Hks rb26 f con v pro gold and loom $850
R34 Gtr front bar and lower lip
black $650
Silver with lower lip, difuzer (average condition) and engine cover section $900
R33 cat back mild steel kakamoto $300
R33 cat back stainless hks $450
R32 cat back jap brand $350
Hks Gtr inter cooler 600x300x102 $600
Trust gtr inter cooler 600x300x70 $450
New apexi spl inter cooler discontinued v tube core $1600
Greddy rb26 plenum $600
Thanks,
Zeke
  • Like 1
https://www.sau.com.au/forums/topic/448062-gtr-parts-for-sale-located-sa/
Hey guys, i have received your pm's, im just waiting on pics from my friend for your requested items and ill send them through asap. If anyone is interested but interstate, please send me your address and ill get a shipping quote. Thanks, Zeke
Sorry not seperating the harness,
Please pm me your number and i can send some pics through of the plenum. The cooler is yet to be located but i am still sorting through mountains of parts.
Thanks,
Zeke
  • 4 months later...
  • 2 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
